wiring harness?
  • 2208 Views
Offline trizacker
  • 37
  • Every Cowboy needs a SIDEKICK!!
wiring harness?
« on: April 12, 2005, 02:04:56 AM »
The wiring harness in my truck is messed the lights do not work, break lights and windows and things dont work. Any way I can rebuild it or some thing ?
Re: wiring harness?
« Reply #1 on: April 13, 2005, 06:23:47 AM »
That sounds like a MOJOR short somewhere in the harness. You best bet would be to get a Factory Service Manual from one of the vendors listed on the main page, go to the wireing section and start tracing wires till you find the problem. It is LONG Tedious work but not real difficult.
Re: wiring harness?
« Reply #2 on: April 13, 2005, 06:55:42 AM »
I would start off with the main fuse block under your hood, go from there to the battery and make sure the connections are real clean.
« Last Edit: April 13, 2005, 06:56:30 AM by mrfuelish »
Offline smitty808
  • 76
  • Hit it with your purse???
    • Godzuki!
Re: wiring harness?
« Reply #3 on: April 13, 2005, 05:58:46 PM »
I have a 1996 sidekick wiring diagram on the FAQ on my website http://www.godzuki.us/faq.htm look for Suzuki parts list, FSM and other info, and click on that link. Maybe that will help you track the problems
250000 miles...and still going! http://www.godzuki.us[/url]
The Bedford Boys!!
http://www.balls-deep4x4.com[/url]
Offline oops-sorry
  • 20
  • just call me oops
Re: wiring harness?
« Reply #4 on: April 15, 2005, 12:28:39 AM »
if none of your electrical is working you might check and make sure that you have a good body ground,  by this i mean a ground wire running from the engine to the body
