Engine Carnage Pics, Now With Bottom End Damage
  • 20 Replies
  • 11106 Views
« on: July 09, 2005, 05:09:26 PM »
Well I tore the head off today and
have some pics of the carnage
The hole starts
Worms thru to the ring land
worked around to the front
The piston was hitting the head
#1 piston is in a lower position compaired to the others
I might not have a broken crank after all
just a bad rod, will know on Monday when I pull
the bottom end apart
Ok The bottom end is apart
Looks different somehow
The block is OK
A paper weight
« Last Edit: July 11, 2005, 10:50:28 PM by wildgoody »
Offline zaggy
  • 1134
Re: Engine Carnage Pics
« Reply #1 on: July 10, 2005, 07:44:32 AM »
Don't you hate it when that happens.....
Zag
Offline locjaw
  • 2045
  • 22
« Reply #2 on: July 10, 2005, 07:51:31 AM »
that is the type af carnage that can happen to engines that are designed to run turbochargers not to mension ones that are not ;D, but those are the chances some people are willing to take  ;)
way to go wild  :o someone has to test these engines and see what they will do ;D
will be waiting for the reports
jason
« Reply #3 on: July 10, 2005, 08:05:01 AM »
Well if you consider the piston have 275,000
miles on them, and they are the stock cast
ones, I think they did quite well. about 25K
miles have been turbocharged
Next ones will be forged turbo pistons,
and should hold up even better, more
power too
Re: Engine Carnage Pics, Now With Bottom End Damage
« Reply #4 on: July 11, 2005, 11:23:40 PM »
bump
Offline prairie_dog
  • 234
  • 85/413 tin top
« Reply #5 on: July 11, 2005, 11:30:07 PM »
 Wild,
   Love the pics of the bottom end, remember the chat we had about turbo's and boost pressure? just yankin yer chain ;D, 275 and turbo is unheard of around here, usually find turbo anything with 275 on it at the pic & pull.
     You got my PM on the glass parts?
Steve
« Last Edit: July 11, 2005, 11:38:51 PM by prairie_dog »
When this thing hits 88 MPH your gonna see some serious sh!t (hahaha)
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #6 on: July 12, 2005, 12:00:22 AM »
Oh well if you're gonna do it, do it good  ;)
Offline zaggy
  • 1134
« Reply #7 on: July 12, 2005, 07:08:46 AM »
We should have a contest for the best carnage pics
     Man I gotta find the ones from the 1.3L/8v that blew at 95oorpm.
     Did the crank make it? Or she be toast?
Hate to see the damage.
Zag
Offline locjaw
  • 2045
  • 22
« Reply #8 on: July 12, 2005, 07:14:50 AM »
wow  :o twisted that rod like a pretzel ;D
jason
Offline zookiemike
  • 474
  • $,reppin Michigan,$
« Reply #9 on: July 12, 2005, 10:20:40 AM »
I feel ya. I snap off three of those suckers :P
As we moving with the speed of the robot sonic exhaust
Chronic fumes, fuel, gin, and tonic
Half of the world is corrupt and alive
The other half is depressed and they want to die
Offline zaggy
  • 1134
« Reply #10 on: July 12, 2005, 10:46:21 AM »
We have a new contender in the worst carnage picture game
Zag
« Reply #11 on: July 12, 2005, 06:27:15 PM »
Well I know ZukieMike lost the whole motor, that's some
serious carnage, I just have the most unique rod shape  ;)
As far as the crank goes, I don't think there is enough
left to turn it out, but I could get it welded and returned.
I'm thinking now about getting this crank stroked about
4-5mm more, cost about $200 I think $20 per journal to
grind and $25 to weld/per
Then I just need a set of over bore pistons, go as big as
I can or take it out 2 mm over stock with some oversize
pistons and I'll get 1751-1770cc  ....hmmm  that ought to
add a little to the power, but I'mm not going to turbo this
one, Turbo is going into a 16V this time
Offline adamd
  • 369
  • sofa king we todd it
« Reply #12 on: July 12, 2005, 06:38:09 PM »
"Turbo is going into a 16V this time"
man you really got to do that!
'98 kick
3" B/l
30" Mud Kings
Offline zaggy
  • 1134
« Reply #13 on: July 12, 2005, 09:42:52 PM »
yo Wild
    Think big, Think mean, think ulitmate power...the WWF of Zukiworld........
compound turbo'd ( 2 X 1.0L Blowers in tandem), intercooled, Nitrous injected, Alcohol fuelled, 1770cc/16v, four wheel tire smokin, rock chchew'n, fear inspiring Master Intimidator of the 4 cylinder world. Striking fear and loathing among those that aspire to compete...oooopppps did I get a little carried away?
Zag
« Reply #14 on: July 12, 2005, 10:43:44 PM »
 ;D  Well if I could find Ethanol or Methanol
at a regular fuelling station, I would go the
Alcohol route, I might be tempted to turbo
this engine, but it would require a special set
of Con Rods, which I don't think I want to spend
the $$ on, with the longer stroke I need to mill the
tops of the pistons, and that means higher compression
so this isn't going to be a Turbo motor, it will however
get a little testing and probably be for sale after it
all checks out OK
