knocking sound???
  • 2532 Views
Offline JDMFUK
knocking sound???
« on: April 13, 2005, 02:23:24 AM »
Went out to play in the mud a couple of weeks ago and on the way home I heard a noise that sounded like grit or grinding, I thought it was the front wheel bearings but now I think it was dirt in the drum brakes. That sound has stopped but now a knocking noise has started when it is rolling, it is not the exhaust hitting anything, it does it on smooth or rough roads. I jacked up the rear end and put it in gear and just let the tires spin in the air to see if I could find the source, went through all of the gears and I don't hear it but when I let it down and drove it it makes the noise. Also it makes whether it is under power or coasting in gear or out of gear. Just wondering if anyone had any ideas. Thanks
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
Re: knocking sound???
« Reply #1 on: April 13, 2005, 04:32:23 AM »
Maybe something with the suspension or shocks in the rear (dented a housing maybe). Just a first guess on first impression......
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline Natebert
  • 1098
« Reply #2 on: April 13, 2005, 04:48:14 AM »
This was what I was thinking, maybe you dented a dustshield on the front calipers.  Still might be a bearing though.  Check your lug and axle bolts.
~Nate
Offline SnoFalls
  • 1358
« Reply #3 on: April 13, 2005, 05:00:41 AM »
is the knock engine speed related or rolling speed related or just occasional?
« Reply #4 on: April 13, 2005, 07:01:39 AM »
You know how those 1973 pintos are off road they just don't LAST.     ;D
Offline domba420
  • 38
« Reply #5 on: April 13, 2005, 08:37:54 AM »
could be a stick stuck in your frame, rubbing a driveshaft, that happened to my brothers zuk once
