Power and fuel economy loss
  • 10 Replies
  • 2824 Views
Offline mudbug
  • Mudbugging
« on: April 08, 2005, 02:58:26 PM »
1.3 1991 Sammy with Calmini header, 2 inch exhaust, 235/75/15 tires, 80p.s.i of engine compression, new plugs, new wires, cap rotor, stock gears and fuel injection.
I can only get the speedometer to hit about 60 and the fuel ecomony is about 19 m.p.g.  Is this normal?  Any suggestions ti remedy this problem?
Jeeps are for people who can't handle a Suzuki!!!
Re: Power and fuel economy loss
« Reply #1 on: April 08, 2005, 03:27:52 PM »
no that does not sound good, I can get 19 with my 33's on  my sammy. start with ecm codes and timing, could be temp sensor or your engine runs too cold? could still be in open loop.
Offline locjaw
  • 2045
  • 22
« Reply #2 on: April 08, 2005, 03:29:26 PM »
its a sammy, that sounds about right.
jason
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #3 on: April 08, 2005, 03:55:19 PM »
80 psi or did you mean 180psi? 80psi is a problem.
« Last Edit: April 08, 2005, 03:56:06 PM by cj »
Offline chet
  • 556
  • Zuki time!
« Reply #4 on: April 09, 2005, 05:18:43 AM »
ya I hope you missed a 1 on the compression !!!
Offline bandit86
  • 1641
  • elv8rguy
« Reply #5 on: April 09, 2005, 09:35:33 AM »
donno, 180 sounds too much, should be 100 to 140psi
mudfkr
« Reply #6 on: April 09, 2005, 10:45:29 AM »
I had a sick G13a which had between 140 to 150 on 1,2,3. No 4 was out for lunch |removethispart|@ 90psi.
I'd say 80 would be luck to running  ???
Offline jzap
  • 515
  • How difficult can it be?
« Reply #7 on: April 09, 2005, 11:49:33 AM »
Check your tire pressure.  Pump them up to about 36 psi (more if the tire is rated for it, and you can stand it) and see if that makes any difference.  My fuel economy drops significantly if tire pressure is down.
Did you correct your speedometer and odometer readings to compensate for the larger tires.  With a larger tire, you are actually going farther per revolution of the tire than the gearing in the speedo head is set up to register.  You need to correct for the shorter distance that you are registering.
Jim Z.
66 Apache camper
Offline TomKat
  • 211
« Reply #8 on: April 09, 2005, 04:59:04 PM »
Anything under 160-ish, stick a fork in it....
88.5 Sammy,YJ's,33's,Yota axles,4.9-1 'case,dents and rust...
Offline Gary_Hill
  • 288
« Reply #9 on: April 09, 2005, 10:20:00 PM »
80psi? rebuild and put a weber/KN on it...but what do I know...?
Offline mudbug
  • Mudbugging
« Reply #10 on: April 10, 2005, 03:00:29 PM »
Sorry, I made a typo-180p.s.i.
I readjusted the throttle position sensor and the power came back.  I will have to run the engine for a while and see if the mileage improves.  Thanks for all of the info.
