Upgrades
  • 12 Replies
  • 5072 Views
Offline blacknight
  • 987
    • Gonzookin
Upgrades
« on: July 16, 2004, 12:25:01 AM »
What upgrade would you like to see for your XL ???
I want to see 3" body lift kit, R&P for the rear and lockers.
George
Offline FlyinGN
  • 35
  • 2002 XL7 Limited
Re: Upgrades
« Reply #1 on: July 16, 2004, 03:32:53 AM »
how about a 'shift kit' for the automatic trans..
Various diff geatsets..
cat back exhaust.
cold air intake
Frank
Offline jagular7
  • 1026
  • Jagular7
Re: Upgrades
« Reply #2 on: July 16, 2004, 04:37:07 PM »
My list is quite long, I'd like to see:
- Anvil with same cv shaft for both sides
- lockers - always, automatic, or manual
- R&P gear selection
- full floating rear axle
- dual t-case
- yoke output t-case
- rid of the center bearing driveshaft
- rid of the rubber isolator joint on rear pinion
- swing up rear door window with split swing open rear tailgate ie. late model Astro van
- swing away tire carrier
- auto trans/engine curve adjustment
- front, rear bumpers
- nerf bars
- belly pan skids
- interior cage
- removable seat covers (leather preferred)
- supercharger
- diesel engine, n/a & turbo/intercooled optioned
- hi-flow cat-back exhaust
- non-pressurized front diff
- turn off/on DRL's
- turn off/on air bags (4wd low only)
- larger gas tank with less ground clearance
- better stereo speaker locations, with more speakers
- manual windows and door locks
- rid of the double hit lock system
- add power window/lock control to passenger front door
- and most of all rear theater seating, ie Xterra, providing rear seat passengers better front view (my kids need this)
So just a few points, most to all these can be done on my own, but I'd prefer to have it already designed in.
Lenexa, KS
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
Re: Upgrades
« Reply #3 on: July 18, 2004, 06:12:52 AM »
George
HEY GEORGE THAT CAR PIC. LOOKS COOL CAN YOU POST A BIGGER ONE THAT I CAN SEE BETTER. I HAD A BLAST AT GONZOOKIN YOU GUYS WERE GREAT & MADE THE EXPERIENCE UNFORGETABLE. HAVE YOU LET DAN LIVE DOWN THE FLAT TIRE YET  ;D  MATTY D.  8)
Offline 1bigtracker
  • 3409
Re: Upgrades
« Reply #4 on: July 18, 2004, 08:34:04 AM »
Offline blacknight
  • 987
    • Gonzookin
Re: Upgrades
« Reply #5 on: July 18, 2004, 09:26:10 AM »
Here's a bigger pic and yes I'm still giving Dan a hard time  ;D
George
Offline FlyinGN
  • 35
  • 2002 XL7 Limited
Re: Upgrades
« Reply #6 on: July 18, 2004, 09:51:52 AM »
fantastic pic!!!
Frank
Offline jagular7
  • 1026
  • Jagular7
Re: Upgrades
« Reply #7 on: July 19, 2004, 01:32:25 AM »
After I sent it, I re-read it and that didn't sound right. Make it "more ground clearance."
Lenexa, KS
Offline nomaad
  • 179
  • I wanna go!!
Re: Upgrades
« Reply #8 on: July 22, 2004, 05:33:27 AM »
I'd like to see a set of replacement flares and floor board kit for trimming about 2" off the wheel wells. The flares would have to be shaped more circular too. The wheel openings now seem to have a straight spot near the bottom. Although this could be an optical illusion since I have the larger tires on. I'd like to be able to fit some 265/70/16s on but then I guess gears would be in order as well.
So fender and wells kit, and gears. Maybe an air locker, but under $300.00.  ;D
Re: Upgrades
« Reply #9 on: July 26, 2004, 01:19:13 AM »
- dual t-case
- nerf bars
- belly pan skids
- interior cage
- supercharger
- turn off/on DRL's
Hey Jag, you dont want much, do you;D
You left out full tube chasis, 36" of wheel travel and 37's :P
Offline truckasaurus44
  • 265
  • I'm a new world Samurai & a Redneck nonetheless!
Re: Upgrades
« Reply #10 on: November 02, 2004, 07:14:34 AM »
Hey Black night, where was that pic taken?  I remember playing on a wreck just like that one at Paragon, PA
Offline blacknight
  • 987
    • Gonzookin
Re: Upgrades
« Reply #11 on: November 02, 2004, 01:30:31 PM »
You got it Paragon down by the 101 area.
George
Offline nomaad
  • 179
  • I wanna go!!
Re: Upgrades
« Reply #12 on: November 04, 2004, 04:31:21 AM »
Hey BK can you upload pics of what you did to fit those 245/75s. What you cut and the like.
Thanks!
