Wheel Question
  • 16 Replies
  • 5886 Views
Offline maxximumsupension
    • www.maxximumsuspension.com
Wheel Question
« on: July 01, 2005, 03:55:56 PM »
Hi all , newbie here !! like this site ...
 Would like to now if somebody replacer oem 16``inch on a Gv1999 by 15`` wheel .If yes Wath wheel did you take and how much Backspacing there ave ....
  The caliper is very near the wheel.... ::)
Offline the_maplebar
  • 466
Re: Wheel Question
« Reply #1 on: July 02, 2005, 04:50:15 PM »
The Chevy Trackers are the same vehicle and have 15" wheels.  Several people have claimed that they brakes aren't any different between the GV and Tracker, Chevy just got the wheels specially made to clear the brake calipers.  But I can't confirm that ;)
Re: Wheel Question
« Reply #2 on: July 02, 2005, 06:21:36 PM »
Okay here is what i have heard.
15s don't fit without spacers to clear the rotors if it came with 16s originally.
They must make 16"inch rockcrawler wheels.
« Last Edit: July 04, 2005, 06:00:01 PM by trickker »
Offline Suzukiwheelz
  • 15
  • Suzukiwheelz
Re: Wheel Question
« Reply #3 on: July 03, 2005, 05:37:22 AM »
If you go to www.americanracing.com and scroll down to application guide.  The company states that the series No 767 will fit but I have not seen any GV with them.
1999 Suzuki GV 2 inch BDS Springs, 2 inch RRO body lift, Old Man Emu struts, Rancho shocks, 30" BFG A/T tires, Cobra CB with PA speaker.  Planning to get custom strut spacer made and a lockright locker in the rear in the near future.
Re: Wheel Question
« Reply #4 on: July 04, 2005, 02:21:11 PM »
ok .....continue to chek for make sure
Offline 97TRAKIN
  • 600
  • Suzuki in Chevy clothing.
Re: Wheel Question
« Reply #5 on: July 09, 2005, 04:45:08 AM »
I'll confirm it for ya. My "00 2-door 2.0 and "04 4-door 2.5 Tracker came with 15" wheels and the calipers are the exact same size as the Vit's. The rims must be custom jobs for these trucks because there aren't many other 15's that will fit.
I have tried fitting my chrome 15" AR wheels from my crashed "97 Tracker and they hit the calipers  on both the newer trucks.
15" rims from the Newer Trackers """WILL""" fit the Vitara.
Offline AJMBLAZER
  • 2166
  • Your mom.
Re: Wheel Question
« Reply #6 on: July 24, 2005, 07:21:16 PM »
Anybody know if this applies to Grand Vitaras?  I've got a line on a set (or two) of aluminum Tracker rims including the ZR2 style and wouldn't mind being able to run 30x9.5R15's or 235/75R15's.
Unfortunately the rims are 700 miles from me so I can't just pop over and test fit them. :P
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
Re: Wheel Question
« Reply #7 on: July 24, 2005, 11:04:53 PM »
15" do fit guy but u will need to space the wheel out 1" and then grind a bit of caliper down i have the american racing wagon wheel with i think -6 offset and it was tight.
01 GRAND VITARA
Offline AJMBLAZER
  • 2166
  • Your mom.
Re: Wheel Question
« Reply #8 on: July 25, 2005, 03:24:25 AM »
Thanks but that wasn't my question, what about the 99+ OEM Tracker wheel?
Offline 97TRAKIN
  • 600
Re: Wheel Question
« Reply #9 on: July 27, 2005, 02:23:17 PM »
THEY WILL FIT. GRAND VITARA, HYPER VITARA it doesn't make a differance. As long as they came from a 2.0 or 2.5 Liter "99+ Tracker.
I am not sure if the 1.6 Liter "99 Trackers have the brakes from the newer or the older models so I can't speak for those.
Offline CE1_2NR
  • 21
  • 2001 GV 4x4
    • Accordingly Done
Re: Wheel Question
« Reply #10 on: July 28, 2005, 11:52:15 AM »
He DID answer your question.
I'd rather be a Dictator than a Dicktaster.....
Offline JDMCRX
  • 1110
Re: Wheel Question
« Reply #11 on: July 28, 2005, 01:15:24 PM »
The canadian GV have 12.5" rotors and when measured with the calipers it measures 14.25"
Now most 15" steels inside diameter is 14.25-14.5 my American racing were 14.5 they fit but the caliper sits future out then the wheel face does so the back of the rim hits the outside of the caliper hense needing the 1" wheel spacer
01 GRAND VITARA
Offline ddement
  • 8
Re: Wheel Question
« Reply #12 on: September 07, 2011, 07:55:55 PM »
15" tracker wheels will NOT fit over the calipers on a grand vitara.
Offline samuraidan
  • 196
  • speak softly, and carry a big stick
    • City Ranger
Re: Wheel Question
« Reply #13 on: September 08, 2011, 10:15:56 AM »
personal experience
 - vehicle: 2000, 2.0L, 4 door Canadian Vitara
 - originally came with 16's
 - could not fit 15x7 rock crawler rims
 - got 1.25" wheel spacers - problem solved
'00 Vitara 2.0L 5spd w/ Jeff's lift, SR Customs body lift, 5.13's, rear locker, SR Customs steel pinion collar, 1.25" wheel spacers, 15x7, 31x10.5R15 Dynapro MT's.
Offline Uncivilized
  • 1469
    • Car Domain
Re: Wheel Question
« Reply #14 on: September 08, 2011, 05:59:52 PM »
Why would you want 15" rims so bad? Seems to me there are more tire options for the 16" wheels, I wanted a set for my old Trackick but couldn't find a set.
