Ticking 2000 GV
  • 4133 Views
Ticking 2000 GV
« on: April 09, 2005, 03:17:32 PM »
Well, i checked out a 2000 GV for 6,999 bucks with 61K miles on it. When they started it, it sounded like the lifters were ticking away a S.O.S.
The dealer said a little ticking (loundly) is normal at the price you can alawys have a shop fix it.
WTF. Not a good answer.
So to you normally get a Tickking noise? It sounded like lifters or a spark jumping, but I didn't want to take a chance.
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
Re: Ticking 2000 GV
« Reply #1 on: April 09, 2005, 06:18:00 PM »
They all tick like that i put some ATF3 in there ran it for a bit did a oil change and the noise is gone.
01 GRAND VITARA
Offline Gary_Hill
  • 288
Re: Ticking 2000 GV
« Reply #2 on: April 09, 2005, 07:12:56 PM »
The ticking is often just gummed up valves and that can be fixed with a can of ENGINE RESTORER ( silver/red can ) from Walmart etc. Follow with oil change and good oil additive such as Duralube. I don't usually recomend "mechanic in a can stuff" but this really works if the problem is actually gummed up valves caused by cheap gas. Eliminate the other maybes such as exhaust leak, loose plug or spark leak ( bad wires ) and don't be afraid of the tick if all else checks out. If you think it is a bad valve do a leak down cylinder check.
You can pinpoint the tick by using a two foot long pvc pipe about 1 inch in diameter.  With your ear on one end , move the other about the motor untill you find the source. OK...when you stop laughing...give it a try
  • 6603
  • 69
Re: Ticking 2000 GV
« Reply #3 on: April 11, 2005, 01:41:38 AM »
These engines have obnoxious valve train noise if they have sit for a long period. If my rig(s) sit for a month or more they tick like mad for a considerable amount of time. What I do is let the vehicle warm up and then go drive around 'the block' that seems to fix it...
Offline Samuraiman
Re: Ticking 2000 GV
« Reply #4 on: July 13, 2005, 08:20:27 PM »
Hey,
The 2.5liter motors are very famous for timing chain rattle that sounds like a ticky valve. Also if you tear it down you notice it is the same poor design toyota had for years and it wears through the guide eventually through the cover. Seen a ton of em that people thought were valves and they ended up being the chain. Also the head tech at the local shop says to be sure to keep oil changed regular and only run 5 30. Just my two cents
Offline ctrimmer
  • 15
  • I'm Rick James     Bitchhhhhhhhhhh hh  !!!!!!!!!!!
Re: Ticking 2000 GV
« Reply #5 on: August 10, 2005, 05:46:29 AM »
Hey,
So is there anything u can do about the timing chain issue? Put a new guide? I'm having this same issue. I will put 5/30 in it and see if any difference... Chad
Offline 97TRAKIN
  • 600
  • Suzuki in Chevy clothing.
Re: Ticking 2000 GV
« Reply #6 on: August 12, 2005, 03:56:21 PM »
The last I heard Suzuki changed the timing chain guide material when they amped up the 2.5 so if you got a "04 or newer you shouldn't have to worry about guides anytime soon, also
I would NOT use any oil other than premium 5w30 in these engines either.
« Last Edit: August 12, 2005, 04:00:18 PM by 97TRAKIN »
Offline ctrimmer
  • 15
Re: Ticking 2000 GV
« Reply #7 on: August 13, 2005, 11:15:35 AM »
I have a 99GV.....so do I need to change the guider?
Offline 97TRAKIN
  • 600
Re: Ticking 2000 GV
« Reply #8 on: August 13, 2005, 04:23:44 PM »
Stay on top of oil changes and use premium 5w30 'Dino or synthetic' and you'll be alright. ;)
