IF I ...........
  • 3331 Views
Offline tonka-toy
  • 154
  • tonka
    • tonka-toy
IF I ...........
« on: February 27, 2005, 08:07:04 AM »
If i put a 1.5 inch spring lift kit and a rocky road 1" spring spacer under our 2000 GV TD what tyres will i be able to get under. 30's would be what i am aiming for as i don't want to send the gearing to far out ( been there done that)
its mainly going to be a road car so extreme flex isn't an issue ... cutting the plastics is a no  no no no no
HELP
Offline sergi
  • 307
Re: IF I ...........
« Reply #1 on: March 30, 2005, 08:34:57 AM »
Hi!
It's nice to see someone else with a diesel engine! ;D
I have no experience with lifts yet, but I have ordered +1.5" springs and already have a 2" bodylift from RRO (still in a box). I plan to try later what shall fit.
In any case, I think you should take a look at nomaad's xl-7, although it may be different from the GV, it should show that it is going to be tight. he has the calmini kit (+2.5") and the body lift, and those 265/70/16 (30.7") are really tight. With the setup you propose, I think a 29" would be much safer (like a 235/70/16).
I insist I hava no direct experience though...
By the way, here is a link to nomaad's tires: http://www.zukiworld.com/cgi/yabb/YaBB.pl?board=xl7_talk;action=display;num=1111683882
Edit: there is a post in this same section that also discusses tires. This is the link:http://www.zukiworld.com/cgi/yabb/YaBB.pl?board=gv_talk;action=display;num=1106454747
« Last Edit: March 30, 2005, 08:41:56 AM by sergi »
Suzuki Grand Vitara 3dr TurboDiesel
Barcelona, Europe
Aquesta és la meva màquina. Creus que em pots seguir?
Offline blacknight
  • 987
    • Gonzookin
« Reply #2 on: March 31, 2005, 05:02:39 AM »
Just a question for you guys with the Deisel's what rear axles are you useing. I ask because I saw someplace a GV TD with a Dana 44 in the rear and they had said it was stock?
George
Offline sergi
  • 307
« Reply #3 on: March 31, 2005, 05:11:01 AM »
hmmmm
I am no expert on axles... But I thought it was suzuki... Suzuki axles aren't dana's aren't they? ???
I'll take a pick of mine so you can figure out ;).
Barcelona, Europe
Offline blacknight
  • 987
    • Gonzookin
« Reply #4 on: March 31, 2005, 05:29:54 AM »
If you have a 3rd member it's not a Dana.  If it has a a bolt on rear cover it could be a Dana.
George
Offline sergi
  • 307
« Reply #5 on: March 31, 2005, 06:05:14 AM »
This is the best pic I could find on my computer. Does it look like a Dana? It does have that rear bolt, but still I don't think that makes it a dana ???
If you need more pics I can take some, the zook is downstairs ;).
Barcelona, Europe
Offline sergi
  • 307
« Reply #6 on: March 31, 2005, 06:06:53 AM »
wow Sorry about the big foto :-[
This one shows too:
Barcelona, Europe
Offline blacknight
  • 987
    • Gonzookin
« Reply #7 on: March 31, 2005, 08:18:08 AM »
this is a Dana 44
Offline sergi
  • 307
« Reply #8 on: March 31, 2005, 08:34:28 AM »
well, mine obviously isn't :(
Barcelona, Europe
