Cylinder Banks for o2 sensors
  • 3050 Views
Offline dfwlee
« on: March 16, 2005, 04:09:37 AM »
Can someone tell me which side of the engine on a 2000 Grand Vitara is Bank one and which side is Bank 2 ? My dealer is being uncooperative, and I haven't been able to locate a repair manual. I recently had the catalytic converter replaced , and am now getting an error code of 0430, Converter opoerating below threshold Bank 2. My dealer saya that this is caused by the O2 sensor needing to be replaced, and he says that it is the rear sensor , bank 2, but I'm unable to determine which side is bank 2. Any input appreciated....Thx....Lee
  • 6603
  • 69
Re: Cylinder Banks for o2 sensors
« Reply #1 on: March 16, 2005, 05:06:19 AM »
Don't quote me on this but I believe that bank one is the front two sensors before the cats and bank two is for the sensors after the cats. Not left and right but pre and post (of the cat) if you will...
I dunno if that helps but maybe it'll jog someone's memory / or jiggle the knowledge tree a little. :)
Offline INGERSOL
  • 158
  • BIG, LONG, AND BLACK
    • INGERSOL.COM
« Reply #2 on: March 16, 2005, 05:54:24 AM »
When I installed my headers ('03 Tracker, 4 cylinder) the made-in Australia caused some problems.
The exhaust manifold has a "pre-cat" built into it location of sensor #1, then there's the main cat, and justy afterwards, sensor #2.  When I replaced the exhaust manifold with the headers, I lost the pre-cat, and the main cat would not be enough to burn up all the crap (and pass an emmissions test) so we had to axe the second cat and replace it with a high flow cat.
Even after drilling and tapping a new bung hole for one of the o2 sensors, I got a CEL code on the dashboard becuase the system did not recognize the new cat as operating within the same parameters as the two factory installed cats (or some bullshit like that).
Bottom line, the second o2 sensor is only there to make sure that you actually have a cat installed (nasty off road polluting sons of bitches sometimes remove/hollow out there cats) but you can trick the computer by installing a $20 " o2 Simulator " which will send the right (if phony) information to the computer rather than taking accurate readings.  I bought mine at http://www.o2simulator.com .  Although your local muffler shop may from on the o2 simulator (and your dealership may simply refuse to install it, it will allow some aftermarket modifications (which may set off the CEL unjustifiably) while still allowing you to pass an emmissions test.
However, all that being said, why not just take the thing back to whoever installed the cat and get them to fix the problem.  Maybe your second o2 sensor (just behind the 2nd cat, closest to the tailpipe) and replace it.
Good luck.
2003 Chevy Tracker
2.0 L Four Cylinder / 5-speed
Suzisport Headers
K&N Air Filter
Calmini Grill Guard / Tube Bumpers UK Factory Sunvisor RRO Coil Spacers Bridgestone Dueler Revo 235/75-15's
