lift for 02 gv
  • 3843 Views
Offline hayes2647
lift for 02 gv
« on: January 22, 2005, 02:32:27 PM »
I wanting to run 31's on my 02 v6 gv and am wondering what lift I'll need to keep the smooth stock ride. I'm wanting mostly for looks ,and won't be doing any serious wheelin. any info would be great.
Tony Hayes
Offline the_maplebar
  • 466
Re: lift for 02 gv
« Reply #1 on: January 22, 2005, 04:04:14 PM »
Well, I am new and haven't lifted mine yet, but I am making plans for it so I will tell you what I know.  According to Calmini you can run 235/75/r15 (about 29") tires with their 2.5" suspension lift.  So you will probably need a  body lift too, since noone offers a bigger lift for the GV.
http://www.puresuzuki.com/tire_chart.htm
http://www.puresuzuki.com/2.5%20Lift.htm
I have seen people claim that they run 235s with a 1"-1.5" coil spacer lift and have little to no rubbing issues so Calmini may be a bit conservative.
Rocky Road Outfitters offers a combo 4" lift (2" suspension, 2" body lift)
http://www.rocky-road.com/kicksus.html
This lift also uses Old Man Emu springs and struts which are supposedly the best riding suspensions for Suzuki's.
Hope this helps.
Offline RIKSTR
Re: lift for 02 gv
« Reply #2 on: February 01, 2005, 04:27:01 PM »
I run a tyre that is about 30.8"
To get it to fit I put 2" tough dog springs and a 1" Body lift ;D
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: lift for 02 gv
« Reply #3 on: February 02, 2005, 02:52:57 AM »
Shoot, the stock tires are 27", and a 29" is only 1" larger in RADIUS.  I think you should be able to run a 29 with no lift at all!  Not that I'm going to try it on my wife's GV...
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline nomaad
  • 179
  • I wanna go!!
Re: lift for 02 gv
« Reply #4 on: February 03, 2005, 12:12:59 AM »
On the XL-7s (which are basically just the extended version) with the Rocky Road coil spacers you can run a 235/75/16 (29.1) with no problems.
With the Calmini 2.5 you fit a 245/75/16 (= to 31x9.5) with minor modifications to the front wheel well. Just bending over the pinch weld at the floor pan and trimming a little plastic inside at the front.
I am currently working on getting 32s under my rig (265/75/16) I have the Calmini 2.5 and I will be installing the Rocky Road 2" body lift and replacing the bumpers with hi-clearance steel bumpers, OME struts, etc...
You can follow it in the XL-7 group. Plus I will be writing up some "how-tos" soon. Most should translate pretty good to the GV as well as I have a 2001 model and they really are closer to each other than say the '05 models.
Offline Suzukiwheelz
  • 15
  • Suzukiwheelz
Re: lift for 02 gv
« Reply #5 on: February 08, 2005, 11:26:33 AM »
The RRO 4.5" lift claims you can run 31(without butchering your ride).  I have 4 inches of lift and I can only run a dissapointing 30" tires without tire rubbing.  After spending all that money I hate it when people cant tell I lifted my vehicle.
1999 Suzuki GV 2 inch BDS Springs, 2 inch RRO body lift, Old Man Emu struts, Rancho shocks, 30" BFG A/T tires, Cobra CB with PA speaker.  Planning to get custom strut spacer made and a lockright locker in the rear in the near future.
