Sammi suspension
  • 1721 Views
Offline tonka-toy
  • 154
  • tonka
    • tonka-toy
Sammi suspension
« on: July 12, 2005, 06:41:29 AM »
what do people prefer and why.
what tyres are under it for what amount of lift
what is the strongest set up using leaf springs and not coils.
at what point do you stop lifting and have a stable truck
got a rolling chassis waiting to be modded and a wad burning a hole in my pocket
need at least 31-32" tyres under it but its gotta be strong and able to work hard
terrain will be a good mix of everything
THANX
« Last Edit: July 12, 2005, 08:31:47 AM by tonka-toy »
Offline bhaugen
  • 140
Re: Sammi suspension
« Reply #1 on: July 12, 2005, 01:05:03 PM »
here has been my progression.
Started with stock spring over lift (4-5" can't remember exaclty been so long), 31" tires ( some fit 32" with some rubbing).  little better flex than stock.  worked ok.
Went to a Ruf (rear springs up front) setup w/31" tires.  Flex improved alot.  Better ride.  little more lift (approx 6"), I also ran 1" wheel spacers to widen the track width to keep it a little more stable.  Could easily fit 32" tires. maybe 33's with moving axle forward 1".   This setup worked out well the only reason I change is because I got a set of YJ springs.
Now I am running the TT YJ kit on toy axles with 33" tires.  Great setup.  It is more pricey, and you need a trac bar, but I am going over stuff.  With the wider stance and no added lift (other than the bigger tire) now It feels more stable than my previous setup.
« Reply #2 on: July 12, 2005, 02:56:05 PM »
I have rears up front on one of my samurai's and it ramped a 944 last week with 33's and 2" back spaced wheels and stock shocks and double main leafs(for axel wrap) in the rear, I have the trail tough yj kit on the floor getting ready to put it in,you can run four leaf for flex with stock bushings or five leaf or the new six leafs that trail tough sells if you don't like the sway but want a great ride and use polly bushings for the street manners your looking for with just a little loss on the ramp(who cares)the springs trail tough sells are not that much more than used ones sell for(not on there web site,ask about them)I will be using a five leaf in the front and a four leaf in the rear with two main leafs and if the u bolts are long enough will add a second leaf to the top for axel wrap.
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
« Reply #3 on: July 12, 2005, 07:24:07 PM »
Running Sky's stage 2 lift with 1 " lift shackles and clearing 32's just fine.
Mean Green Wheeling Machine
