creeky ball joints
  • 2163 Views
Offline bus_driver
  • 479
  • the voices tell me different things
creeky ball joints
« on: July 16, 2005, 12:59:47 PM »
ok I think I finally narrowed it down to the ball jionts.....does this mean the are worn or dry?
can I just pop of grese and pop back on?
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline zaggy
  • 1134
Re: creeky ball joints
« Reply #1 on: July 16, 2005, 01:06:53 PM »
Check them ouot and see if they have grease fittings or fitting plugs
If they have grease fittings just grease the beast
If they have the fitting plugs (looks like a 6-8mm bolt) in the bottom of the ball joint, take them out and install grease fittings, then grease the beast
While you are there check the play in the ball joint, if it isn't to spec after greasing, replace.
If it doesn't have etheir...gotta replace the balljoint
Zag
Offline bus_driver
  • 479
« Reply #2 on: July 16, 2005, 01:33:58 PM »
so I can's just pop off and grease huh?
they are 90 bucks each!!! most expensive thing yet!
92 2dr soft top
235/75/15
2 inch lift
custom mud
« Reply #3 on: July 16, 2005, 01:47:22 PM »
if you jack the car up by the frame and they pop apart that would be a cheap 90.00.
Offline bus_driver
  • 479
« Reply #4 on: July 16, 2005, 02:35:35 PM »
thank you !!! had that one covered
the only reason I am thinking re grease is becuz I did a lot of water crossings and I am wondering if they can dry out? since they are not greasable.
I will have to check there tolerance b4 I do anything.
92 2dr soft top
235/75/15
2 inch lift
custom mud
Offline zaggy
  • 1134
« Reply #5 on: July 16, 2005, 02:41:01 PM »
I think I can get you a better price than that...let me check at the shop when I go in tonight.
Zag
Offline bus_driver
  • 479
« Reply #6 on: July 16, 2005, 02:43:07 PM »
ok, there is one other shop I have to check also. they are sometimes great and sometimes horrible on prices
92 2dr soft top
235/75/15
2 inch lift
custom mud
« Reply #7 on: July 16, 2005, 04:05:08 PM »
One thing you can try, that is if the Ball Joints
are good, is to install a Zerk fitting into the bottom,
but use a low profile one so it doesn't get knocked
off by some greedy rock  ;)
You can modify most ball joints this way if they
don't come with a plug or Zerk installed
Offline zaggy
  • 1134
« Reply #8 on: July 16, 2005, 06:42:40 PM »
Yo Bus Driver
     I can get you those Balljoints through my shop 45.00 each Canadian you pay the freight
PM me
Zag
