How do you reconnect the Check Engine light?
  • 2758 Views
Offline rottyfan
  • 15
« on: July 21, 2005, 10:34:28 PM »
A year ago, when I purchased my 1998 Tracker, the Check Engine light was on.  The salesman assured me that it was probably a sensor that needed to be replaced and he assured me that they would fix it and not just pull the bulb on the Check Engine light.  Sure enough when I took the car home, the Check Engine light was no longer on.  However, the speedometer was not working.  I had to turn right around and go back to the dealer so they could reconnect the speedometer cable.  In retrospect I should have suspected the reason why the speedometer got disconnected was when they disabled the Check Engine light.
Anyway, last week I took the Tracker in for emmission testing and it failed.  Two codes came up: P0400 EGR Flow Malfuction; and P0740 Torque Converter Clutch Circuit Malfunction.  Before I try messing around with these codes I figure I better get the Check Engine light working first.  Can anyone tell me how to go about reconnecting the Check Engine light?
Thanks
Annoy a Liberal:
Work, Succeed, Be Happy
Re: How do you reconnect the Check Engine light?
« Reply #1 on: July 21, 2005, 10:37:57 PM »
They probably just pulled the bulb,
get in there and see if you just need
to replace it, hopefully they didn't
toss the bulb holder too
Offline Suzuki1.8
  • 283
  • Tires so low looks like i'm riding on blades
« Reply #2 on: July 22, 2005, 05:48:23 PM »
What state you in? I had the same issue with mine the check engine light was missing and first year emission failed. THe dealer pulled the light . Luckly all it was was a o2 but still made me mad. You can acutally go back on the dealer for modifeying the emissions. You could go to the state or just threaten to turn them in.
