Calmini Heim joint size?
  • 3680 Views
Offline ksa421
  • 382
« on: July 25, 2005, 01:02:53 PM »
I have the 3" Calmini susp lift and the Hiem joint on the rear upper control arm is going out. Does anyone know whats size this is and where i can get a replacement?
'90 Kick, Calmini 6" lift, 32x10.50 Pro Comps, Calmini bumper, 8000lb winch, 1.6l VW TD;
Offline 1bigtracker
  • 3409
Re: Calmini Heim joint size?
« Reply #1 on: July 25, 2005, 02:14:13 PM »
do a search for "rose joint" i think it was, you'll find it there.
Stu
Offline ksa421
  • 382
« Reply #2 on: July 25, 2005, 03:29:53 PM »
Thanks that helped but then I ended up taking the lazy route and called Calmini and it should be here in 4 or 5 days :) i guess I had it too far out.. You are only supposed to have 3 or 4 threads showing, mine is like 1/2" out  :-[
« Last Edit: July 25, 2005, 03:32:14 PM by ksa421 »
« Reply #3 on: July 25, 2005, 09:37:24 PM »
That explains why mine fell out. :-[ ;)
"O" Well. Thats fixed.
Know I gotta fix the motor. :-[
120k and now smoking like a smoke stack
Offline ksa421
  • 382
« Reply #4 on: July 26, 2005, 01:39:29 AM »
Well I just so happen to know someone selling a couple of replacments that would rid you of your tired motor woes ;D ;)
GRVIT
« Reply #5 on: July 26, 2005, 04:04:50 AM »
anyway,its a 3/4-16  heim joint.I know cause I got 8 for my sas project.Available at Spidetrax and many other places.....
« Reply #6 on: July 26, 2005, 05:48:29 PM »
"O" Really? We'll have to get together and talk. ;D
Right now the poor thing is on Garage duty.
Offline Agent Orange
  • 711
    • Trying to learn
« Reply #7 on: July 26, 2005, 10:20:16 PM »
ther are 3/4-16 heim joints, i called calmini for the size. although i bought my replacements from a local shop that sells aurora teflon lined joints. they only costed me $48 canadian each, and boy did it fix the problems i had with the old one. no more squeeks, or read axle bump steer.
