rear diff
  • 1842 Views
Offline 99tracker
  • 14
rear diff
« on: July 29, 2005, 06:08:09 PM »
i just want to know if there is any chance that a 99 tracker would of came stock or an option dif.because if i dump the clutch i'll dig two holes in 2wd and foure in 4wd .maby a ltdslip or something.
99tracker/k&n filter/rest is stock for now
Offline jagular7
  • 1026
  • Jagular7
Re: rear diff
« Reply #1 on: July 31, 2005, 07:41:50 AM »
Really doubt that you have anything in traction aids in the differentials. As an older driver, I would say to you to not to continuously 'dump' the clutch. The reaction within the drivetrain is a shock to the system. The engine spinning against the friction of the tires on the ground. Something in between will either bend or break. Think of it like someone pulling on your arm. If you are relaxed, it could pull out of the shoulder if the pull was hard enough. If you are prepared, you could pull a muscle or pop a joint.
Reason you are seeing 2 marks from the axle is because the reaction is jolting the drivetrain. Both tires loose enough traction and spin. A much better way of determining if you have traction aids is to lift a tire in the air on the rear axle. Use a floor jack or the vehicles jack, with trans in neutral and 1 tire in the air (parking brake off), spin the tire and see if you can. If you can, there is no aid. The ds should also spin.
Lenexa, KS
Re: rear diff
« Reply #2 on: July 31, 2005, 01:59:35 PM »
Wait for winter, put one wheel on some ice,
you will know in short order if you have one
Offline 99tracker
  • 14
Re: rear diff
« Reply #3 on: July 31, 2005, 06:11:05 PM »
did'nt think so thanks anyways
