16v header
  • 2008 Views
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
16v header
« on: August 04, 2005, 12:18:41 PM »
I'm looking for a 16v header. I don't really like the Calmini because I don't think the down toobs are long enough to produce enough gain for the $. Petroworks was working on a real header w/ doug thorley, but it still isn't out :(
     Thanks ,
     Kevin
Offline zaggy
  • 1134
Re: 16v header
« Reply #1 on: August 04, 2005, 12:59:21 PM »
What else have you done to the engine?
     The stock tube type exhaust manifold looks pretty good, maybe just go with a good exhaust till a header you like comes out.
Zag
Re: 16v header
« Reply #2 on: August 04, 2005, 01:14:46 PM »
What does yours look like now? both of mine have twin tubes coming down off of the cast iron manifold which look good to me.
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Re: 16v header
« Reply #3 on: August 04, 2005, 02:02:09 PM »
I have a Calmini one on my 8v trakick and I like it but the one for the 16v is alot shorter. It's cast for about 10" then goes into one 2" tube down until the cat. What I was looking for was one like the 8v with the long down tubes for midrange.
     Kevin
Offline zaggy
  • 1134
Re: 16v header
« Reply #4 on: August 04, 2005, 02:51:09 PM »
See if you can find some pics of your header and post them.....
     The reason I say that is the Canadian ones are a tube type header that look alot like the Calmini one...they appear to be a fairly high flow design and they are not that expensive to buy new. That's why I suggested keeping the stocker and going with a good exhaust.
     But if yours is a cast iron one then it's a different game and you might want to find the Canadian tube type one.
Zag
