Fuel Leak
  • 1907 Views
Offline steveofrost
  • 457
  • '91 SS JLX 4-Door
Fuel Leak
« on: August 05, 2005, 06:53:49 AM »
Hey everyone! Wow, its been so long, the forum changed its look! Anyway, I noticed a gas smell coming from under the hood the other day and couldn't figure out where it was coming from. I left it for a few days because I thought it was just the exhaust smell from my (yes again!) broken exhaust system. The weird thing was it was a raw gas smell, so I left the truck running and noticed gas bubbling right around where the throttle cable (is that what it's called?) is located. Is there a gasket around here that can be easily replaced??
Thanks guys!
steveo
Re: Fuel Leak
« Reply #1 on: August 05, 2005, 07:30:08 AM »
On the TBI system there is a little O-ring
that seals the fuel line, remove the 2, 10mm
bolts and remove the O-ring, you might need
a small sharp hook to get it off, you can buy
a seal hook for this purpose, and get a new
quality nitrile O-ring from your friendly local
parts house
Should do it, and welcome home
Steve
Offline steveofrost
  • 457
  • '91 SS JLX 4-Door
Re: Fuel Leak
« Reply #2 on: August 08, 2005, 11:41:28 AM »
Thanks again Wild! Everything was exactly how you said. Problem solved!
steveo
Re: Fuel Leak
« Reply #3 on: August 08, 2005, 06:44:09 PM »
 ;D  That's what we are here for
Offline Carnage
  • 2453
Re: Fuel Leak
« Reply #4 on: April 06, 2006, 02:57:52 PM »
can anyone help ME out?   :'(
Re: Fuel Leak
« Reply #5 on: April 06, 2006, 10:14:56 PM »
With ???
You got a fuel leak ?
