toy axle info needed
  • 2223 Views
Offline schaan
  • 38
  • iili,
    • thpppppp
« on: August 11, 2005, 03:21:11 PM »
i need a good forum like this one to find out more about my yota axles and if its like 9",r's im used to   are they really drop out and interchangable?
also  wanting to talk to someone who has hooked up dual sami cases?
any help?
the more i know..., The more I know..!,
I Dont Want to Know Any More. !!
1992 sami ,toy axles ,full frame with exo
Offline locjaw
  • 2045
  • 22
Re: toy axle info needed
« Reply #1 on: August 11, 2005, 05:09:37 PM »
try this place they seem like nice people(not as nice as here,but that is hard to find)
http://wildyoats.com/wild_yoats_entry.htm
jason
Offline Chief
  • 678
  • Whaddya lookin at??
« Reply #2 on: August 11, 2005, 05:30:51 PM »
yes, the 8" is a drop out third like the 9".
No idea on the dual sammi cases.
Offline 37kicker
  • 319
  • 97 tracker 9inch front and rear on 40" pitbulls
« Reply #3 on: August 11, 2005, 07:51:11 PM »
they are also interchangeable. front & back
Offline Ian
  • 50
    • Island Rock Crawlers
« Reply #4 on: August 12, 2005, 09:55:38 AM »
Check over on Pirate for dual sammy cases.  It has been done a few times but there are a few issues that make it a pain.  The cases are underdriven in high range (1.41:1) so when you add in a second case you end up with a high range of 1.99:1.  Almost as low as the stock low range.  The way the cases are mounted also makes it really difficult to come up with a solid mounting method for two cases.  You are better off looking at using a sidekick trans and tcase and putting them in front of the sammy case.  There are several examples of homebrew methods that work well for this.
Offline red_baron
  • 108
  • little red vit
    • surrey zuki society
« Reply #5 on: August 12, 2005, 10:34:19 AM »
 I have just made a twin t case for my hybrid.
toyota axles on a lwb track (vitara over here)
was easy to make.
building cross members at the mo.
« Reply #6 on: August 12, 2005, 02:06:19 PM »
The 1.6 is a reasonably straightforward swap for the 1.3. It has been done lots of times so there is plenty of info and lots of people to give advice. The 1.3 responds very well to a Weber carb and header (around same peak power as the 1.6, less torque). Weber can give problems on steep inclines. Zaggy is the man for tuning Zuk engines.
