What exhaust u got on ur Grand Vitra V6???
  • 40 Replies
  • 12792 Views
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« on: August 11, 2005, 04:02:56 PM »
Im thiking of doing a 2.5" manderal bent with a flowmaster 50 series delta muffler and 3" tip
what u guys got???
01 GRAND VITARA
Offline AJMBLAZER
  • 2166
  • Your mom.
Re: What exhaust u got on ur Grand Vitra V6???
« Reply #1 on: August 14, 2005, 05:29:14 AM »
The 2" stock one.
My plan is to just have a shop hack off the OEM muffler and replace it with a 2" in/out Magnaflow muffler and a few inches of pipe.  The factory pipe should be plenty wide for an engine of this displacement, might just be stainless steel (at least it looks like it to me), is routed and bent nicely, and on ours, is in pretty good shape.  Magnaflows are straight through so they should flow much better than our OEM mufflers.
2.5" seems way to wide for our little engines.  With 2.5" wide pipe I'd think you'd loose a lot of the scavenging affect and your power would move much higher in the power band.  These things are already rev motors, don't want to loose much of the low end you know?
Offline 97TRAKIN
  • 600
  • Suzuki in Chevy clothing.
« Reply #2 on: August 14, 2005, 05:55:07 AM »
The 2" stock one.
^My thoughts exactly^.
The factory pipes are stainless thats why when they fail they usually fail at the resonator ( that little mini glass pack at the tail pipe).
The pipes and cats on the newer 2.5 are the same size as the ones on the 2.7. I think this is the main area Suzuki got the power increase from.
So if I had the ealier 2.5 I would start with an exhaust system upgrade for more power before I did anything else.
Offline JDMCRX
  • 1110
« Reply #3 on: August 14, 2005, 07:14:28 AM »
The newer GV have a 2 1/4" exhaust but the muffler is huge.
My exhaust is the small version which is like 2" all the way back. These motors are a Quad valve and like to rev due to our rod to stroke ratio you can rev them pretty high.
The reason im going with 2.5" is due to reving and also this winter when i get posted im gonna put a paxton blower on it and SDS engine management.
IM gonna do the exhaust and fix up my heat shield on my intake and im gonna put my dads stock rims on my truck and dyno the truck and see what number we can get and get CE1 2NR to put his on cause his is stock.
01 GRAND VITARA
Offline JDMCRX
  • 1110
« Reply #4 on: August 14, 2005, 07:16:10 AM »
Another thought is this motor has small exhaust manifolds and two pre cats and a tiny down pipe so i think this will keep enough back pressure for low end scavanging.
01 GRAND VITARA
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #5 on: August 14, 2005, 12:18:09 PM »
How new?  My '03 has 2" from the cat back.
Offline JDMCRX
  • 1110
« Reply #6 on: August 14, 2005, 12:28:16 PM »
Well the GV's ive seen here im pretty sure were 2 1/4" here in canada maybe i am wrong but fuck the OEM one is tiny.
I do know this in canada the 99-01 come with smaller exhaust then the 02-05
01 GRAND VITARA
Offline 97TRAKIN
  • 600
« Reply #7 on: August 14, 2005, 12:53:32 PM »
"04 and up, atleast here in the US.
Offline JDMCRX
  • 1110
« Reply #8 on: August 14, 2005, 01:53:36 PM »
Im gonna have to go measure it cause the 05 i saw had a 2.5" tip and look like a 2 1/4" exhuast.
01 GRAND VITARA
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #9 on: August 14, 2005, 01:58:18 PM »
My tip is around 2.5" too.  The pipe itself is 2".  A section of 2.25" pipe left over from my Ranger is noticeably wider.
Offline JDMCRX
  • 1110
« Reply #10 on: August 14, 2005, 02:21:12 PM »
Hmm im gona have to go look and measure but im sure with the 2.5" ill make some good power.
01 GRAND VITARA
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #11 on: August 14, 2005, 03:21:54 PM »
Just for shits and grins, why not go down to your local parts place and pick up a proper width glasspack or cherry bomb and some pipe and slap that in place of the factory muffler.
I bet you'll see a big improvement.  They'd be straight through so you'd see a noticeable increase in flow and only for $20 or so (US, it's Sunday, you'll have to convert to Canadian).  If you like it, find a muffler you like and put it on in the cheapies place.  If not, you're only out $20 US or so and can go on with your plan.
Just a thought.
Oh yeah, wanting higher flow and putting a Flowmaster on is kinda working against yourself.  Flowmasters have chambers and baffles inside.  That means the free flow of air is blocked and redirected...a lot.  Kinda hard for them to be free flowing.  Maybe better than OEM type mufflers but there are better flowing mufflers out there.
Offline JDMCRX
  • 1110
« Reply #12 on: August 14, 2005, 03:56:15 PM »
Ive heard a GV with some midas speacial and a cherry bomb and wow sounds like shit. Ive heard a GV with a cherry bomb and stock pipes ehh not a fan im gonna try the flowmaster and 2.5" and a resonator and see what kids of gains i can get.
01 GRAND VITARA
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #13 on: August 14, 2005, 05:41:43 PM »
I ment just throw on a better flowing muffler than stock that's relatively cheap and see what the performance gains are.  If you like the gains, go buy a good 2" muffler.  If you want more, you're out $20 and have a bit more knowledge about what to expect.
Offline JDMCRX
  • 1110
« Reply #14 on: August 14, 2005, 05:55:17 PM »
Oh yeah i do not wanna cut up the orig muffler as its mint ill build the exhuats on sat and let u guys know how it fairs out
01 GRAND VITARA
