Probleme Fuel Pump !!!
  • 2117 Views
Offline Dr_xXx
  • 28
  • Yes Baby !!!!
« on: August 15, 2005, 05:21:48 PM »
hi...i have remove my fuel pump and the top whit the 2 hose one presion exit et one return on the top, i have broke this part on the return hose....see picture.....
how you call this part ? i dont have to change the pump ? my pump run perfectly !!
ftp://quebec:4x4|removethispart|@142.217.202.58/pumpgaz.jpg
Sidekick 90 2 Door
3" Body Lift
2" Suspention Calmini
31 Mud BFG !!!
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: Probleme Fuel Pump !!!
« Reply #1 on: August 15, 2005, 09:38:19 PM »
I call that part the fuel pump hanger. You can fix it by letting it dry very well, then brazing on a new fitting.
Offline Dr_xXx
  • 28
  • Yes Baby !!!!
« Reply #2 on: August 16, 2005, 09:02:08 PM »
its possible names Sending unit ? what is the Sending unit ?
Sidekick 90 2 Door
3" Body Lift
31 Mud BFG !!!
Offline Digger
  • 1991
« Reply #3 on: August 16, 2005, 10:03:51 PM »
Yes, but you have to be careful because the fuel gauge float assembly is also called a sending unit, but is totally separate from the pump assembly...
Offline keith
  • 1176
« Reply #4 on: August 17, 2005, 06:47:04 AM »
I had similiar issues so I bought a tank and pump on e-bay for $60 and replaced the whole assembly.
Offline Dr_xXx
  • 28
  • Yes Baby !!!!
« Reply #5 on: August 19, 2005, 08:33:12 PM »
i have rebuilt myseflt its easy...just weld whit little bottle of propane whit brake line its great work !!!
Sidekick 90 2 Door
3" Body Lift
31 Mud BFG !!!
