OTT steering question
  • 2687 Views
Offline mbmarkyb
  • 461
    • UK Vitara
« on: August 16, 2005, 01:39:21 AM »
hello
Does the OTT steering bolt up to the King pin bolts ?
Markyb (UK)
UK Vitara JLX SE
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: OTT steering question
« Reply #1 on: August 16, 2005, 03:07:33 PM »
hello
The SJ-413/Samurai has an upper kingpin held in place by 4 bolts on top of the front axle's steering knuckles.  In my experience, Breeze's OTT kit is attached via the upper kingpin mounting system.  I believe other OTTs work this way too.
Hope this helps!
Ack
« Reply #2 on: August 16, 2005, 10:50:46 PM »
on the rocky road one I had it hooked to the four king pin bolts and had a piece that was welded to it that bolted to the two caliper bolts also, the king pin bolts on a samurai are not that strong, toyota maybe,my trail tough ott has two large mounting bolts that replace the caliper mounting bolts and looks to be alot stronger, sky and a few others attach the same way.
Offline nc_zuk
  • 406
  • Back in North Carolina
    • www.samurai4x.com
« Reply #3 on: August 18, 2005, 08:31:25 AM »
The Rocky Road Outfitters and Breeze Industries setups bolt to both the 4 kingpin bolts and the two brake caliper bolts. These are GREAT setups for sure.
The Sky Manufacturing, Trail Tough, and Acme Adapters setups only bolt to the 2 caliper bolts. Althought I would think that they are not as strong I have yet to hear of any breaking.
www.Zuwharrie.com[/url]
Where the road ends........... Zuwharrie begins !!!
