1.6L 8valve Needs Cheep Power Upgrade
  • 1902 Views
Offline SunrunnerGT
  • 163
  • 1994 Pontiac Sunrunner GT and 1996 X90
    • Aaron's Suzuki
« on: August 17, 2005, 10:54:42 PM »
I was wondering, what are the cheepest ways to get some more power outa my 1.6 8valve motor??
Sunrunner GT, Gold Trim Level
Re: 1.6L 8valve Needs Cheep Power Upgrade
« Reply #1 on: August 17, 2005, 11:03:43 PM »
Bang for the buck a cam will make the most
difference, a header next and a 2" exhaust,
after that a K&N filter would help with the
deep breathing.
The bigest problem with the Cam is the head
has to come off the get the cam in and out  :(
I put off doing my Cam until I had to pull the head
for a valve job, and then I should have done the
rings (200,000 miles) but the power was really
there after the swap.
Offline zaggy
  • 1134
« Reply #2 on: August 18, 2005, 07:03:35 AM »
As usual
     Wild has hit the nails on the head. I would do the header, 2 or 2 1/8 exhaust with a good low restriction muffler and a K&N Drop in filter first.
     When the engine is ready to be redone then the cam and if you check around the board there are some other things you can do at the same time the engine is being rebuilt.
Zag
