ring and pinion options
  • 1864 Views
Offline jimmyn
  • 17
« on: August 18, 2005, 11:33:50 AM »
I run 31X10.50 R15s on my 92 sidekick. Which has OME total package and 1 1/2 coil spacers. I want a 5.83:1 ring and pinion, but  can't find one. What are my best options. Thanks for the help. Can I use another 4X4 such a a scout or bronco or any other that has a r&p close to what I need. I need input. Thanks Jimmy
« Last Edit: August 18, 2005, 03:09:42 PM by jimmyn »
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Re: ring and pinion options
« Reply #1 on: August 18, 2005, 12:50:45 PM »
Hey Jimmyn, Is your kick an auto or 5 speed? The reason I ask is if it's an auto you can run 5.12's. Which is stock in a 5 speed and available everywhere but now for the 5.83's I say good luck.
    Kevin
Offline jimmyn
  • 17
« Reply #2 on: August 18, 2005, 01:34:43 PM »
Its a 5 speed.
Offline ZeusZuki
  • 411
« Reply #3 on: August 18, 2005, 11:17:44 PM »
Just a note of interest.
Over here in NZ if it is a three speed auto ( usually in the 8V's ) then they are fitted with 4.6:1 r&p's. If it is a 4 speed auto it has 5.13:1 r&p's.
Zeus ;)
