What weight oil are you running in trans and transfer?
  • 18 Replies
  • 4830 Views
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: What weight oil are you running in trans and transfer?
« Reply #15 on: August 26, 2005, 09:27:27 AM »
nice takeoff.....bet that landing was a bit choppy though ;D
Nah, simple manouver - roll right and climb out to the top of the hill...  :eek:
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #16 on: August 26, 2005, 08:02:00 PM »
I run synthetic in the trans and regular lube in the t case. I change my fluids at least 3 to 4 times a year also. (thats about every 8-10k miles)
Mike
Why so often?
As some have aparently noticed I do abuse use ;) my rig to the fullest extent. My trans and tcase fluids seem to be burned, dark and light metal shavings after that many miles. I tend to run a lot of high rpms under load and wheel very often. In the winter the deep snow is really hard on the t case lube with a 4 to 1 case. Those t case gears are really spinning fast when your in 5th gear low range. Ive had smoke comming out of the breather tube and shifter boot before. (It was torn) I just feel better knowing that the simple things are taken care of. I dont think this would be nessicary of most drivers.
Mike
BTW, I dont think the flying is cause for changing t case fluid! :P
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #17 on: August 27, 2005, 11:17:54 AM »
Doesn't syn. oil mess up the brass syncrows (very bad spelling).  I've used it in two tranys and both have lost their syncrow...
32 MTR's Warn 8000i
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #18 on: August 27, 2005, 08:59:24 PM »
Ive never had a problem with that. Ive crushed the small bearing on the lower shaft a couple of times grabbing second gear though. Unfortunatly there is no oil that can help me with that yet. ::)
Mike
