rear coils
  • 1591 Views
Offline 92Sidekick4x4
  • 1456
rear coils
« on: August 24, 2005, 04:38:55 PM »
yes this subject again, i did a search but didnt find my answer
What coil would compare to using a calmini 3" coil??
Offline Chief
  • 678
  • Whaddya lookin at??
Re: rear coils
« Reply #1 on: August 24, 2005, 05:30:31 PM »
None that I know of. The diameter is kinda odd, from what I have gathered. No other "bolt in" solution.
I'm going custom mounts and using coil over springs eventually. In the front also, just for shitrs n grins.  8)
  • 1456
Re: rear coils
« Reply #2 on: August 24, 2005, 06:04:37 PM »
what about heating the coil near the top so it fits right into the spring cup?
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: rear coils
« Reply #3 on: August 24, 2005, 09:13:45 PM »
Heating the coil destroys the temper of the steel and hurts the elasticity and any changes made under the heat will only be temporary. Search back to the topic I had started about coil swaps and there is info in there about different application coils that are close. I beleive Ranger/explorer/Bronco 2 front coils are pretty close, but need pressed closed a little at one end to fit the cup...
