sidekick to sami trans/tcase?
  • 1909 Views
Offline wezzlegod
  • 227
  • under construction crowler
« on: August 24, 2005, 05:55:16 PM »
 can a sami trans mount to a sidekick 1.6 motor. im trying to get the reduction of the
sami's hi and low t case. the sidekicks tcase is a one to one so the hi gear cant be redused.
is thare a adapter for just the sami tcase on a sidekick trans? what can i do other than ring
gears i have 5.12s. i do not want to do too much fabbing. ??? ??? ??? ???
Offline cj
  • 1276
  • I drive a really big ATV
Re: sidekick to sami trans/tcase?
« Reply #1 on: August 24, 2005, 06:08:16 PM »
Yes it can be done but it definately requires fabbing.
Offline zukin
  • 54
« Reply #2 on: August 24, 2005, 06:45:37 PM »
you need a OTT kicker 3.
here is the link.
http://www.ottindustries.com/kicker3.htm
Offline 1bigtracker
  • 3409
« Reply #3 on: August 25, 2005, 02:47:14 PM »
a samurai trans(1.3L) can be adapted to a tracker(1.6L) engine with any of the kits on the market for the samurai.  you will need to have drive shafts made, build a crossmember(some fabing) and mabey cut the floors for the shifters.  i think the clutch cable is in the same place.
Stu
  ÂÂÂÂÂÂÂ
