Toyota Power Steering on a Tracker Questions
  • 1820 Views
Offline Skunk
  • 147
  • Offroadnuts.com
    • Offroadnuts.com
« on: August 25, 2005, 12:59:56 PM »
OK, need toy p/s setup, does anyone have any writeups or detailed pictures on their steering setup?
Im lookin for pics of how the box is mounted, and how the pump is adapted to the engine. also, what pitman arm or adaptor was used, I currently have a 3/4" heim setup.... and how was the draglink adapted to the new box
Thanx in advance for the help.
98 SFA Explorer - D44 front, 8.8 rear both locked on 35's, Man. T-case, Warn XD9000i
94 Tracker  Toy locked axles 5.29 r/p's, toy steering, 4.24 t-case, 35" MT's, YJ leafs, warn 9500hs
Offline mesjr2004
  • 422
Re: Toyota Power Steering on a Tracker Questions
« Reply #1 on: August 25, 2005, 04:49:04 PM »
ive got the toy box and tracker pump. let me see if i cand find some picts . what i can tell you is i welded 3/4 plate to the frame and drilled and tapped it to mount the box to. and im using stock pitman arm
Offline Skunk
  • 147
  • Offroadnuts.com
    • Offroadnuts.com
« Reply #2 on: August 26, 2005, 09:03:44 AM »
how did you attach the new pitman arm to your exsisting linkage? I know the pitman arm has a male balljoint on it.
Offline Skunk
  • 147
  • Offroadnuts.com
    • Offroadnuts.com
« Reply #3 on: August 26, 2005, 08:47:14 PM »
got the parts, and started on the project, took all the old stuff out, did some cutting to fit the new stuff, now it just mounting it all and adapting one to the other.
Offline mesjr2004
  • 422
« Reply #4 on: August 27, 2005, 06:05:10 PM »
i got all of my linkige from ott, took the measurements they ask for and they sent me the linkige
