Full Time Front Hubs
  • 16 Replies
  • 3468 Views
Offline izook
  • 9
  • Greetings
    • iZook.com
« on: August 25, 2005, 05:53:46 PM »
Hello Everyone,
I am in search of a set of front hub replacements. Not sure of the Suzuki truck they are from but I know they exist.  They look like a set of "full time 4wd" hubs. They take the place of the normal auto or manual hubs on the front axle.   These lock the axle engaged all the time.
I need them for my full floater axle on the rear of my truck. I have tried all hubs, stock and aftermarket and they are not staying locked on the highway. If you have a lead on a set or know the vehicle they came on please let me know.
Thanks Larry
iZook.com Publisher
http://www.izook.com
Re: Full Time Front Hubs
« Reply #1 on: August 25, 2005, 06:45:35 PM »
I think you are looking for the front lockouts
that come on the newer Trackers with the
shift on the fly type system, I belive they are
electric activated like on a Grand Vitara
Please elaborate on the hubs that are not
staying locked, why do you think this is ???
I was planning on a similar setup, but with
lockouts, I might need to rethink the setup.
Thanks
Offline locjaw
  • 2045
  • 22
« Reply #2 on: August 25, 2005, 07:13:04 PM »
i have had the same problems with my floater rear. i put on drive flanges, not sure what they came off of but it is a newer zook (like a xl7 or gv) if i can find my kids camera i'll take some pics and post them
WARNING... they do not stay tight, i have to continualy check them and tightn them up once a while (lost one once)
but thay do solve the problem of the hubs disengaging and you can unbolt them and slide the axel out
jason
« Reply #3 on: August 25, 2005, 07:15:34 PM »
Why would the hubs unlock ???
I have never had any trouble with them
on the front of the Kick
Offline zukin
  • 54
« Reply #4 on: August 25, 2005, 07:20:58 PM »
they came on sammy's as standard equipment.
free wheeling hubs were an option with sammy's.
I might have a set, will do some digging .
Offline locjaw
  • 2045
  • 22
« Reply #5 on: August 25, 2005, 09:19:12 PM »
hubs on the back with a locrite =bad news
too much torq and side movement when the locker does it's thing, kicks it out and rounds the leading edje and you through the hub away (and the day of wheeling)
here are pics of the flanges
let me know if you have any questions
jason
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #6 on: August 25, 2005, 10:11:24 PM »
As has been mentioned the early zooks had these standard and the other option is the newer GV's and XL-7's. I found this out when investigating building a full floater for the rear. I was told to use these as the manual hubs don't tend to cut it in this use by someone who has a full floater on a Sammy and had them fail but the flanges work fine.
« Reply #7 on: August 25, 2005, 10:23:12 PM »
OK, I see the problem now,  There are no
problems, just challenges and solutions
« Reply #8 on: August 25, 2005, 11:52:51 PM »
Ya those come stock on my m38, they have lasted 52 years so I guess there strong  8)
Offline izook
  • 9
  • Greetings
    • iZook.com
« Reply #9 on: August 26, 2005, 02:42:17 AM »
Yep, those are the flanges I am looking for.  Anyone know where I can get a set? Thanks everyone.
Larry
iZook.com Publisher
Offline locjaw
  • 2045
  • 22
« Reply #10 on: August 26, 2005, 06:56:17 AM »
i got both sets at the wrecking yard, i think like $20 each set. the only thing i carry spares of are...rear floater axels , a spindle and those drive flanges (cause they do loosen for no reason)
use grade 8 bolts (i use hex key bolts)and a lock washer NO LOCTITE(if they break you will never get them out, and they will break)
the full floater is great BUT it does require frequent maintinenced
if i had to do it all over again i'd go toyota axels(and still might)they are not unbreakible but they are tougher than hell
jason
Offline izook
  • 9
  • Greetings
    • iZook.com
« Reply #11 on: August 26, 2005, 09:31:49 AM »
Jason,
What vehicle are you taking them off? And your location?
Larry
iZook.com Publisher
Offline izook
  • 9
  • Greetings
    • iZook.com
« Reply #12 on: August 26, 2005, 12:29:35 PM »
Found one truck they come on. 01 - 04 XL7. Now I need help finding them. None here in West Michigan.
Larry
iZook.com Publisher
Offline locjaw
  • 2045
  • 22
« Reply #13 on: August 26, 2005, 01:45:37 PM »
do you want me to see if i can find a pair?
just pay what i do +shipping and i'll try to find them
jason
Offline izook
  • 9
  • Greetings
    • iZook.com
« Reply #14 on: August 26, 2005, 02:17:31 PM »
Yes please and thank you.
Larry
iZook.com Publisher
