x-90 2wd to 4wd whats involved
  • 11 Replies
  • 4859 Views
Offline fallguy
  • 127
« on: August 27, 2005, 11:36:07 AM »
guys whats involved in converting a x-90 2wd to 4wd from my understanding i  was told that i need a sidekick t-case and front axles d-shaft steering and struts   how much of this is true
 thanks
Offline Dihnekis
  • 398
Re: x-90 2wd to 4wd whats involved
« Reply #1 on: August 27, 2005, 12:25:51 PM »
I'm in the process of converting my trackick 2wd to 4wd. I haven't actually started anything but I'm workin on getting all the parts... I found a guide for an x-90 that should help you.
http://bbs.zuwharrie.com/content/topic,20946.0.html
Other than Ronin on zuwharrie I don't know of anyone who has done it, and no one on here seems to really know the all part differences. I'm getting a FSM and hopefully it will give me a list of the parts that differ.
1988 Suzuki Samurai
Offline 1bigtracker
  • 3409
« Reply #2 on: August 27, 2005, 01:42:36 PM »
ok from what i've found, every part interchanges but there is one bracket that need to be welded on.  It should be a simple swap.
Stu
Offline Dihnekis
  • 398
« Reply #3 on: August 27, 2005, 06:41:48 PM »
Stu you know if I need that bracket too? If I do, know which bracket it is/ where I can get one?
1988 Suzuki Samurai
Offline 1bigtracker
  • 3409
« Reply #4 on: August 27, 2005, 06:58:33 PM »
You know that a X90 frame is the same as a kick right?  that artical you found would work just the same on your kick.
Stu
Offline jzap
  • 515
  • How difficult can it be?
« Reply #5 on: August 27, 2005, 08:59:06 PM »
Stu
With that being the case, wouldn't the easiest solution be just to lift the body off and mount it on a 4WD Tracker frame???
Jim Z.
66 Apache camper
Offline Dihnekis
  • 398
« Reply #6 on: August 27, 2005, 11:21:59 PM »
No I didn't know an x-90 and a kick had the same frame, thanks for letting me know.
And yes it would be easy to drop my body on a 4wd frame, if I had a 4wd frame or the money to pay for one.
1988 Suzuki Samurai
« Reply #7 on: August 28, 2005, 08:57:20 AM »
Stu
That article is for an X90, like it says you will also need the correct front diff or R&Ps.
Offline fallguy
  • 127
« Reply #8 on: August 28, 2005, 10:46:00 AM »
thanks guys you have been really helpful it all makes sense now
Offline Dihnekis
  • 398
« Reply #9 on: August 28, 2005, 12:22:12 PM »
Stu
What do you mean? Can you elaborate a bit? Won't the correct front diff come with my complete axle hub to hub that I'm picking up? It is from a 5 speed, so it should have the 5.12 gears, and I have a 5 speed so the gears should match right?
1988 Suzuki Samurai
« Reply #10 on: August 28, 2005, 01:24:55 PM »
Stu
Sorry, I got my nested quotes wrong  :-[ The X90 has a 4.62 front diff (or thereabouts) The Kick is OK.
Offline Dihnekis
  • 398
« Reply #11 on: August 28, 2005, 02:06:55 PM »
Would anyone with a stock trackick axle and transfer case setup mind taking a few pictures of underneath showing the mounts for the front axle, transmission, and transfer case? I'd really appreciate it. I have no 4x4 trackicks in my area that I can look under, and I want to get an idea of how it differs from mine. I have a manual coming soon and that should help, but pictures would be greatly appreciated if someone has some spare time.
1988 Suzuki Samurai
