Removing underdoor panels...
  • 2623 Views
Offline thedeep
  • 50
« on: September 01, 2005, 07:45:11 AM »
A friend said he saw an article/video online walking through the process of removing the plastic underdoor panels and replacing them with something else. Anyone know where I can find that? Gotta get rid of these things. Thanks.
Offline Uncivilized
  • 1469
    • Car Domain
Re: Removing underdoor panels...
« Reply #1 on: September 01, 2005, 09:13:52 AM »
Do you mean the plastic rockerpanel covers?
Offline thedeep
  • 50
« Reply #2 on: September 01, 2005, 09:29:46 AM »
Yep. Those evil little bas***ds that collect rust. I've got the plastic off, but what to do with the brackets? I think, maybe, I'll go with a set of diamond plate covers, but I assume one removes the brackets first.
Offline chet
  • 556
  • Zuki time!
« Reply #3 on: September 01, 2005, 11:05:31 AM »
you can use a spot weld drill to get them off or grind the heads of the spot welds down. Just be careful not to grind into the rocker itself.
You can then paint the rocker with rocker guard or paint it body color. For protection I would mount a bar under the rocker or cut the rocker out and replace it with a square tube.
Offline dsumers
  • 72
« Reply #4 on: September 01, 2005, 10:44:07 PM »
square tube? That sounds interesting.. Have any pictures?  What size square tube?
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #5 on: September 02, 2005, 03:25:38 AM »
Try:
http://www.izook.com/tech/samurai/body/ncorockers/ncorockers.htm
in Izook.com's tech section.
It's an illustrated  tutorial for installing replacement Calmini diamondplate rockerpanels that shows how to remove the underlying metal brackets.
Ack
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #6 on: September 02, 2005, 05:31:32 AM »
Do you have a Sami or Trakick?
The article is for a Sami.
Some where on this sight rocker gards were discussed (for a Trackick).  Someone cut cut out the rockers and replaced them with square tubing welded to where the rockers used to be.  Turned out quite well.
32 MTR's Warn 8000i
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #7 on: September 02, 2005, 05:39:10 AM »
I found a couple nice threads, but don't know how to post them?
Go up to the "search button"  and type in "rocker gards" and they will come up.
32 MTR's Warn 8000i
