Belt questions
  • 2096 Views
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Belt questions
« on: September 01, 2005, 05:58:21 PM »
On the Goblin, I removed most of the AC system because it was in the way and adding un needed weight. I'd like to remove the compressor, too, but not until I find a shorter belt. Did these rigs ever come with power steering and no a/c? Is there a belt that is the right size if I just tell the parts guy 93 with PS but without AC or will I have to custom size one?
Re: Belt questions
« Reply #1 on: September 01, 2005, 06:59:22 PM »
They come without a/c but not sure if yours has the same bracket? just take some ribbon and a stapler with you and pop the hood so you get get the correct size at the auto parts place.
Offline zaggy
  • 1134
Re: Belt questions
« Reply #2 on: September 01, 2005, 07:26:40 PM »
Hey Digger
     The info I've got says you can use the non-a/c stock belt....put and bracket should be the same.
Zag
Offline prairie_dog
  • 234
  • 85/413 tin top
Re: Belt questions
« Reply #3 on: September 01, 2005, 09:15:27 PM »
 I got a 90 sidekick in the garage ( good parts) it's got PS and no AC, I'll get the number and brand off the belt.
 Your PS runs off the outer crank pulley right? ( inner for the ALT and outer for PS) if so the belts should be the same.
 I'll post belt #s tomorrow when I get off work
 Steve ;D
Offline Digger
  • 1991
Re: Belt questions
« Reply #4 on: September 03, 2005, 05:34:58 AM »
Cool... yeah the outer belt spins the ps and the ac... It's a flat belt, too, not a V-belt...
Offline echojeff
  • 414
  • Lo que sea
Re: Belt questions
« Reply #5 on: September 03, 2005, 08:55:43 PM »
Why not turn your ac compressor into a air compressor?  I have a jeep friend who did that to run his lockers and air up at the end of the trail ride.  Works quite well.
Jeff
95 Kick 4dr JLX.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: Belt questions
« Reply #6 on: September 03, 2005, 11:47:17 PM »
When I took my engine out, I noticed that the PS pump could be locked down or pivoted indicating that, with the AC compressor not installed, you can adjust the belt tension with the PS pump.
I think that the locking bolt is under the pump and accessable through the round holes in the pump's pulley.
Whatever the case, take a good look at the way the PS pump is mounted and you'll discover how to set it so it'll take the slack out of the belt.
Hope this helps!
Ack
