What Brand Oil Filter Are You Using?
  • 2477 Views
Offline holman
  • 42
« on: September 06, 2005, 12:39:52 PM »
I'm getting ready to change the oil and oil filter in my Sidekick.Just wanted to know what brand filters people are using.
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
Re: What Brand Oil Filter Are You Using?
« Reply #1 on: September 06, 2005, 12:51:04 PM »
As far as I know WIX is the best filter you can buy. I read somwhere that they have the finest micron filtration. I run WIX on all my vehicles. They have great Air filters too.
If yours is a 16 valve the part # is 51348
More info goto www.wixfilters.com
Mike
« Last Edit: September 06, 2005, 01:02:36 PM by Mikerpm4x4 »
Offline keith
  • 1176
« Reply #2 on: September 06, 2005, 12:52:38 PM »
I read somewhere (maybe here) that the Wal-Mart filters are pretty good filters.  That is what I used at the last change.
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #3 on: September 06, 2005, 02:36:01 PM »
I use pennzoil.  I used to use the better longer-life filters.  I'd rather just replace a standard one more often now, plus it costs less.  I used to use fram tough guard.  Never had a problem with them, just don't know if i got any better advantages of using it or not.
PZ-26 in pennzoil for 8V and 16V engines.
1993 4-door Sidekick
4.24:1 t-case
« Reply #4 on: September 06, 2005, 08:57:55 PM »
Wix or a Napa Gold, are the best filters
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #5 on: September 06, 2005, 09:02:44 PM »
I usually use K&N oil filters. they have a valve built in that keeps oil from draining back into the pan that supposedly helps prevent dry starts... Whether it actually works or not, I don't know...
« Reply #6 on: September 06, 2005, 09:06:02 PM »
It does work, Wix filters have that too
