tach help
  • 1910 Views
Offline MYJL
  • 11
  • GO Cowboys!!
tach help
« on: September 07, 2005, 10:16:38 AM »
Installing an aftermarket tach on my 1990 samurai. Which side is the negative side on the coil? any help is appreciated. I need to know where to hook up the green wire coming off the tach.
« Last Edit: September 07, 2005, 11:24:52 AM by MYJL »
1990 Samurai
Re: tach help
« Reply #1 on: September 07, 2005, 08:12:57 PM »
Take the cover off the coil and
look at the connections, one will
have a - sign and one will have
a + then you just hook it up
Offline MYJL
  • 11
  • GO Cowboys!!
Re: tach help
« Reply #2 on: September 08, 2005, 07:05:38 AM »
This is not the old style round type coil. It is square,has the wire coming from the distributor and a plug in with two wires on it from the main wiring harness.
1990 Samurai
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
Re: tach help
« Reply #3 on: September 08, 2005, 07:15:20 AM »
Maybe I'm too simple for this stuff but can't you just hook up a multi meter or something of that kind?
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline MYJL
  • 11
  • GO Cowboys!!
Re: tach help
« Reply #4 on: September 08, 2005, 04:42:36 PM »
Don't have a meter  but in case anyone else needs to know in the future,the green wire from the tach goes to the noise suppressor. It has a brown a black and a brown with white wire. The wire from the tach attaches to the brown wire.
1990 Samurai
