crown vic on rear
  • 17 Replies
  • 5511 Views
Offline bus_driver
  • 479
  • the voices tell me different things
crown vic on rear
« on: September 09, 2005, 12:31:47 PM »
are very nice great ride and withe the one inch more droop I actually get good flex with stock everything....
so thank you too who ever found out this little idea
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: crown vic on rear
« Reply #1 on: September 09, 2005, 12:33:48 PM »
Actually I measured them to be 1-1/2" longer than the new stock ones and $5 cheaper each, too!
I'm very happy with mine! I agree, BIG thanks to whoever found this out! LOL!
  • 6598
  • 68
« Reply #2 on: September 09, 2005, 12:45:45 PM »
Do you guys have actual shock model and part numbers? Or, has that already been posted?  :-[
« Reply #3 on: September 09, 2005, 12:47:46 PM »
Mike told me about them,
I got 98 Ford Crown Vic rear shocks
and I like the flexxxxxxxxxx   ;D
Offline Digger
  • 1991
« Reply #4 on: September 09, 2005, 12:48:42 PM »
The ones I got were from Advance. They were Monroe gasmatics for the rear of a 91 Crown Victoria. I've heard that rear shocks from the E-150 vans work also...
*** this is #1000 post for me, woohoo! LOL!***
  • 6598
  • 68
« Reply #5 on: September 09, 2005, 01:32:31 PM »
Subtle! :)
Offline Dihnekis
  • 398
  • I love YaBB 1G - SP1!
« Reply #6 on: September 09, 2005, 02:00:00 PM »
So they flex better than the stock shocks? Do you have to have any kind of lift (spacers coils etc) for them to fit?
1988 Suzuki Samurai
31" BFGs, SPOA, 5.14 Calmini Tcase gears, DOM cage, rock sliders, spidertrax wheels
1.6L, header, and 2" flowmaster exhaust coming soon
Offline Twan013
  • 98
  • meh.
« Reply #7 on: September 09, 2005, 07:49:56 PM »
first of all, congrats digger!
second, does anyone know about the e-150 springs?  i've heard that using e150 springs and GV springs will give you a 2 inch lift...  I want to try it out, but i figured it would make the ride super stiff, since the springs are made for such heavy vehicles..
third, i always thought it was the springs that gave you flex instead of the shocks... i thought shocks were just used to cushion the bumps and stuff.... can anyone explain or add to my comments and quesions?
Offline Digger
  • 1991
« Reply #8 on: September 09, 2005, 07:55:56 PM »
The tech archive article that mentioned E-150 springs was a typographical error. They meant E-150 shocks. E-150's use leaf springs in the rear.
Longer shocks allow longer travel which means more flex because they allow the axle to droop further. To fit the longer shocks on my truck, on Silver I use 1-1/2" coil spacers and on the Goblin I use 2" Calmini lift springs.
Offline Twan013
  • 98
  • meh.
« Reply #9 on: September 09, 2005, 08:33:49 PM »
well that's a big 10-4!  i always thought they used leaf springs, but figured the e150 is an oddball vehicle or something.... thanks for clearing it up for me
« Reply #10 on: September 09, 2005, 09:14:30 PM »
I tried the F-150 shocks, way too long,
that's when Mike said try the Crown Vic
shocks.
I run a 3" spacer on a stock rear shock
Offline Twan013
  • 98
  • meh.
« Reply #11 on: September 09, 2005, 10:02:37 PM »
its me again with basically the same question...  i CAN use GV springs to give me a lift, right?  i hate to sound stupid or stubborn, but i don't want to spent $700 or more on something that i can get for 200 at most.. i want a lift (not body), with a fairly comfortable on-road ride, and fairly decent flex...
« Reply #12 on: September 09, 2005, 10:06:57 PM »
You will get some lift, but the rate will be higher
than the stock springs, I don't know how much
lift you will get, but I would think only 1 inch or
so, not as much as a lifted suspension kit
Offline Digger
  • 1991
« Reply #13 on: September 09, 2005, 10:17:35 PM »
Using GV or 4 door springs will get you some lift for your 2 door, but only because they have a higher rate, therefore they can hold up more weight. I don't know if they are any longer than stock. This means that any lift they provide will be also making the ride that much stiffer and harsher. If you like the way your rig rides now and don't really want to make it stiffer, then you're gonna have to either go with coil spacers or pop for a kit with longer springs.
Offline SnoFalls
  • 1358
« Reply #14 on: September 10, 2005, 01:09:47 AM »
I put the rear springs from my 4dr into my 2dr ...
They are about 1/2" (maybe 3/4") longer free, and a little stiffer (but not that much). Overall I think it put an extra 1" at the rear.
