window track insert
  • 3154 Views
Offline thedeep
  • 50
window track insert
« on: September 11, 2005, 12:17:16 PM »
When I roll down my driver's window, the liner follows. I don't see any clips, does it just glue in? If so, what kind of glue? I'm rustproofing the interior of the door and adding diamond plate door panels. Just need to secure the window track, first.  As always, thanks in advance for the help.
Re: window track insert
« Reply #1 on: September 11, 2005, 01:10:54 PM »
I like silicone, but I hope you never
need to get it out  :)
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« Reply #2 on: September 11, 2005, 02:34:03 PM »
3M also makes a releasing agent if you need to take it out sometime down the road.
http://www.autobarn.net/3mweatad5ozt.html
  • 6598
  • 68
« Reply #3 on: September 12, 2005, 06:24:58 AM »
Samurai? Sidekick? If a Samurai, I'd suggest going to your local favorite junk yard and getting the window channel from a Sidekick/Tracker and installing that in your Samurai first before the ga-lue.
HTH, -Eric
Offline TN_Tracker
  • 1113
« Reply #4 on: September 12, 2005, 03:21:35 PM »
...Samurai? Sidekick? If a Samurai, I'd suggest going to your local favorite junk yard and getting the window channel from a Sidekick/Tracker and installing that in your Samurai first before the ga-lue.
HTH, -Eric
 :-\ But glue is more fun ;D
  • 6598
  • 68
« Reply #5 on: September 12, 2005, 03:26:56 PM »
HTH, -Eric
True...
But the Samurai felt runners are icky in comparison to the rubber Sidekick channel material. It's a nice upgrade and most junk yards will give you the 'soft stuff' like that.
Offline TN_Tracker
  • 1113
« Reply #6 on: September 12, 2005, 03:30:54 PM »
True...
Didn't know that, learn somethin' new here every day. 8)
