Red line
  • 10 Replies
  • 3043 Views
Offline Suzuki1.8
  • 283
  • Tires so low looks like i'm riding on blades
Red line
« on: September 12, 2005, 07:48:10 PM »
So i got to thinking the other day when pulling a trailer with my sidekick. What rpm is it bad to hold the engine at for long periods of time. Because when i'm on the freeway normal crusing speeds of 75 to 85 is 4500 to 5000 rpms. WHen pulling a trailer i sometimes hold around 6000 to 6500. I have a sport and with my chip i can take it to 8 grand. WHen racing i shift at 7500. These things seem to get most of there power at higher rpms. I always watch temp and oil pressure and it never gets hotter then half or pressure never get to high or low. What do you guys think?
Re: Red line
« Reply #1 on: September 12, 2005, 08:08:48 PM »
When it blows up let us know so we can tell you  ;D
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
Re: Red line
« Reply #2 on: September 12, 2005, 11:35:38 PM »
Well since wild does drove it in mostly stock form with a turbo for so many miles I guess they're pretty tough, but my 8v hits the rev limiter at 6500 rpm if I recall correctly.
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Re: Red line
« Reply #3 on: September 13, 2005, 08:41:40 AM »
I pretty much keep it below 6000
highway cruise on 30" tires with
5.83 gears is 5000 |removethispart|@ 70 MPH
Re: Red line
« Reply #4 on: September 13, 2005, 09:25:48 AM »
Hey wild,how did ya come up with those numbers? I think that you would be closer to 3500 or so!
Offline Suzuki1.8
  • 283
Re: Red line
« Reply #5 on: September 13, 2005, 06:50:41 PM »
well i have a 1.8. and just normal freeway speeds i'm well over 4500. But the questions remains is it bad to hold it above 6500 for long periods of time towing.
Re: Red line
« Reply #6 on: September 13, 2005, 10:00:40 PM »
I would say yes, do not tow at that high of an rpm for very long, the 1.3's will take nine grand all day long(so i've heard) the 1.6 maybe six or sixty five hundered rpms once and a while under a load, but the 1.8's are not that common for most of us but if it has a longer stroke than a 1.6 I think that sixty five hundered towing is to many r's, just my gut feeling.
Re: Red line
« Reply #7 on: September 13, 2005, 10:10:10 PM »
Uhhh, Driving it   ;D
Go use the gear calc, it should confirm it
Re: Red line
« Reply #8 on: September 13, 2005, 10:14:54 PM »
I did I used yours it said 3600 and change. I used an over drive calc but you might not have one eh! the 1.8 should have one.
Re: Red line
« Reply #9 on: September 13, 2005, 10:31:03 PM »
And where have you been ???
I'm driving a 89' 1.6L 3 speed Auto Trans
Assuming a 30" tire measures 29" really
I spin 4750 RPM |removethispart|@ 70 MPH
Re: Red line
« Reply #10 on: September 13, 2005, 10:41:04 PM »
i'm running 5.88's and only turn 3670 with a 30" tire.  O.D. ;D
