Why is a solid axle better for wheeling?
  • 30 Replies
  • 9133 Views
Offline SNAFU
  • 40
« on: September 14, 2005, 05:44:59 PM »
I come from a road racing background and I would like to know why you would not want all four wheels on the ground as much as possible, instead of hanging out in space when off roading.  Anyone care to fill me in?
Alan
When I grow up I want to be Stewie Griffin.
Offline Agent Orange
  • 711
    • Trying to learn
Re: Why is a solid axle better for wheeling?
« Reply #1 on: September 14, 2005, 06:03:18 PM »
not an expert on the subject, but it depend on the wheeling your doing. outside of heavy rock crawling ifs can do everything else as good or better in some cases. everybody has their opinion. one thing is for sure though, if you build an ifs rig and end up not liking it, you can always convert to sas. although if you start out sas, and you end up not liking that, you can't go back. so best advise is know what type of wheeling you want to do, then read, and ask questions you'll get all the help you need right here.
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #2 on: September 14, 2005, 06:56:35 PM »
Stability is even more important than keeping all 4 wheels on the ground. I dont think a strait axle is better, I do think they are simpler to go extreme with. That does not make it better. That being said I dont dislike straight axle rigs, I just prefer IFS. I might not want Ifs on a full size but I like how nimble trackicks are with IFS.
Mike
« Reply #3 on: September 14, 2005, 07:03:05 PM »
First you need to define "better"
IFS rigs tend to pick up a wheel
more often when getting off camber,
not a bad thing, it's just one of the things
an IFS rig does.
I watched some guys driving sammys down
a boulder strewn road, and they were getting
thrown back and forth, my Kick was "doing it's thing"
with the IFS taking most of the rough ride
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
« Reply #4 on: September 14, 2005, 11:32:10 PM »
pressure on tires, straight axles when one side goes up other goes down.
ifs can go in two different directions with out one effecting the other.
buy one of each see which one you like better.
now if I can just convince the wife to let me have a 3rd vehicle.
Mean Green Wheeling Machine
Offline explosivo
  • 3157
« Reply #5 on: September 15, 2005, 03:39:45 AM »
As posted earlier, it depends on your preference.
Solid axles are generally stronger and flex better in rocks/technical trail riding, but IFS can be made strong and flexy (just take a look at Mike's rig). One of the biggest downsides to a solid axle is the on-road ride quality, even when using sway bars. IFS is just tons better if you're driving your rig on the road.
Oh yeah, IFS generally costs more to build up nice and strong than a solid axle does.
Again, it all boils down to what you want to do with your truck. Niether is better than the other in every aspect. :)
omghi2.us[/url]
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #6 on: September 15, 2005, 05:41:06 AM »
i will let you know how i find my live axle i am just about to finish it this saturday morning as i have to be at a club weekend saturday afternoon.
I know for sure my road handling is going to be a lot worse now im running a live axle on coils.   but the amount of flex i have gained equals my rear setup,  I have had to limit it.
My truck isnt my daily driver so having lots of body and bump steer isnt going to worry me to much.   if my truck was my daily driver i would have probably stayed with IFS.
a pic from a couple of weeks ago.
Markyb (UK)
UK Vitara JLX SE
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #7 on: September 15, 2005, 08:44:40 AM »
Where'd you get the idea that an SFS setup means you'd be hanging out in space more often than IFS?
Actually the reverse is true. More flex means more tires on the ground at all times.
IFS:
SFS:
It all depends on the wheeling you're doing. If you're mudding or high speed desert racing, or just moderate logging roads, then yes, IFS is fine. If you're a rock crawler, or you need to be in areas where flex is involved, SFS is the way to go.
Sure, you can make an IFS perform close to an SFS suspension, and an SFS perform close to an IFS suspension, money is the only limiting factor.
Heather Galvin
« Reply #8 on: September 15, 2005, 08:54:36 AM »
Cool pics, I know those guys (and gals  ;D )
« Reply #9 on: September 15, 2005, 08:55:25 AM »
My Kick, it looks so tiny compared to the others  :o
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #10 on: September 15, 2005, 08:58:31 AM »
 ;D
I haven't been surfing on here too much lately.. I don't think I even have any wheeling pics or have done any "wheeling" in my truck since it's been camoed. I've got a serious itch to, though.
Just been workin' and playing PC games. haha..
Heather Galvin
« Reply #11 on: September 15, 2005, 09:03:32 AM »
;D
Dont feel bad, I bow-tied a tie rod on my last trip and have been to lazy to fix it.  :P
Offline SNAFU
  • 40
« Reply #12 on: September 15, 2005, 10:09:14 AM »
Simple, an independent suspension allows both wheels to follow the road contours independently, instead of being forced to do the opposite of what the wheel on the other side is doing.  Looking at pics of SFS Samis when one wheel is down in a crevice the other is way up in the air, whereas if it had an IFS the wheel not in the crevice would be reaching downward trying to get to something for traction, and will contact the other side of the crevice and get traction sooner than an SFS as the vehicle moves forward.  I don't see how you can say a SFS has more "flex" than an independent suspension.
From your pictures it does look as though some of the vehicles have much more suspension travel than the others (is that a kick with a SFS at the bottom?).  Maybe we are at odds on terminology (flex vs what I call travel).  Maybe its easier to get a lot of travel out of a SFS?
« Last Edit: September 15, 2005, 10:15:26 AM by SNAFU »
Alan
Offline SnoFalls
  • 1358
« Reply #13 on: September 15, 2005, 10:58:49 AM »
The primary reason an SFS will "flex" better is that as one wheel is compressed, it applies a force on the oposite to extend. With IFS, a wheel on a bump will not interact with the opposite wheel (hence independent), and so that oposite wheel is more likely to raise into the air.
In those first 2 pics of heathers, you can see that the RHS tire is hanging in the air (there is no "force" trying to cause it to extend downward other than the weight of the tire. In the SFS pics, the RHS whell is being forced down into the crevice and more likely to grab some traction .
Even travel wouldn't help the crack crossing above for IFS rigs much. There just isn't the needed forces to get that pik'd tire into the crack. (and travel is more difficult to achieve with an IFS on these things, it can be done, but not as easily as with a solid front axel.)
« Reply #14 on: September 15, 2005, 11:12:43 AM »
A comment regarding the pic from Heather.
We came up behind a group of much larger SAS rigs crossing when we came through the crack. And all of the Kicks, mostly IFS walked right through the exact lines the much larger SAS rigs took  ;D With some of them having trouble  :o
And the ol-IFS kept them on the ground prety good  8)
We were trying to get a good 3 wheel line for a pick  :P
