Drive shaft vibration vitara - calmini 3 inch
  • 21 Replies
  • 8051 Views
Offline pepperoni
  • 6
« on: September 16, 2005, 04:32:04 AM »
I've been reading the forum and you guys have the answer for everything.  I'm from Sydney and own a 1995 Vitara Estate (4 door) 1.6. EFI.
I've just installed the 3 inch Calmini Suspension Lift and all went together ok, except much longer than the four hours they estimated.  More like days.
I'm happy with the ride height and even the harder ride.
I can't stand the vibrations coming from the drive shaft.
I've been moving the diff angle around (moving the rod end in and out on the upper vbar) with differing success.  At the best I can hear slight noises from the drive shaft at low speeds no vibrations.  At higher speeds 110km to 120km/h (60 -70 mph) a resonating sound happens, usually when lifting the foot from the accelorator.  You can nearly eliminate the noise if you push down slightly on the accelorator as you slow.
Is there a trick to it.  Ive been told to try and have the two difs at the same angle (the thread nearly all the way out of the bar) but this wasn't any better.
I'm waiting on BF Goodys 235 75 15s and have stock 205 70's on at the moment.  Will this make a difference?
Can someone give some advice or an easy remedy.  Surely this is an easy fix.  Help.
Pepperoni
95 Vitara Estate 3 inch calmini suspension
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
Re: Drive shaft vibration vitara - calmini 3 inch
« Reply #1 on: September 16, 2005, 05:24:48 AM »
If you had the drive shaft apart (probably not but worth a try) you might have assembled it not exactly like it was that can cause such thing....
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline Chief
  • 678
  • Whaddya lookin at??
« Reply #2 on: September 16, 2005, 06:07:14 AM »
Your vehicle has been modififed from stock, different vibrations, noises, etc are to be expected. It's all part of the game!
Come ride in my trackick, yours will then feel like a caddy! ;D
Offline chet
  • 556
  • Zuki time!
« Reply #3 on: September 16, 2005, 12:47:28 PM »
you need to buy one of those cheap angle gauges. stick it on the output of the tcase and measure the angle. To get the vibs gone you have to have the same angle on the diff. Also you probably have one or possibly both U-joints worn and the lift is compounding the problem.
Offline chrisvitarasport94
  • 228
« Reply #4 on: September 16, 2005, 02:28:56 PM »
if a uj got strained in fitting the kit you could have busted a bearing that was gonna let you down soon anyway -
Offline suzukiboyoz
  • 194
  • Friends don't let friends ride a Yamaha
    • http://community.webshots.com/
« Reply #5 on: September 16, 2005, 02:45:17 PM »
Mate have the same kit in my Vit and have tried different positions on the rod end same vibration just different level of noise.
As Chief said has to be expected after sure big mod.
pepperoni don't worry about the 235 75 15s and go for a set of 30" fit fine no rubbing at all.
Calmini 3" Suspension Lift, Calmini Skid Plates, Calmini Rockhoppers, 30" Mud TYres, ARB Bullbar, Rear ARB Locker, Custom Sill Sliders, Rear Bumper and a lot more.
Offline pepperoni
  • 6
« Reply #6 on: September 16, 2005, 03:02:06 PM »
Thanks for the tips.
I'm pretty sure that the larger noises aren't doing my driveline any good.  Even if I knew it wasn't causing damage I don't think I can take the noise.
Some of the trips I do can be over a nine hour drive in 100km/h to 110 km/h zones everytime I back off I'll get this drone through the drive shaft.
Am going to try a few more adjustments and then start looking at balancing  and rechecking the drive shaft.
Am I trying to fix something that can't be fixed or have any of you guys installed the Calmini 3" kit and are totally free of vibrations / noises?
Pepperoni
Offline Speedracer7c
  • 2210
« Reply #7 on: September 16, 2005, 03:24:59 PM »
I've had the same thing with mine for almost 2 years now, I just live with it.
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #8 on: September 16, 2005, 04:54:23 PM »
Never noticed any vibes in mine. Can I ask why you are going with such small rubber with that suspension?
Offline pepperoni
  • 6
« Reply #9 on: September 16, 2005, 05:49:02 PM »
CJ
Re the tyres.
There's a couple of reasons.
At the moment the dollar value is a big thing.  The Misses let me have the suspension lift and will only allow the Goodrich tyres but no more major mods at the moment.  Yeah yeah I know, what are listening to her for.  I do have a mortgage as well.  Any way  I'm happy with that choice.
If I do go the bigger tyres I'll have to go the bigger rims, standard Suzuki 5 spoke 5.5 inch rims at the moment.
With the increase in rubber I don't know what my insurance company will be like.  I definitely need the cash if it's totalled.
Same questions with the law as well.  Don't get me wrong there are plenty of 4Wd's on the road over here running 33's and up  but at the moment I'm happy to go slowly upwards.
Also I start to wonder about the gearing.  My car isn't exactly a powerhouse. You would also have to think lower gearing for the 4WD (Rockhoppers etc) and extra $$$.
Back on the other subject with the vibrations.
Can you tell me if you had to adjust the rod end at the vbar  to get no vibrations.  How far out have you wound it.  I'm thinking that with the same kits and same vehicle there can't be much difference in the adjustment.  Any help would be appreciated.
Pepperoni
Offline cj
  • 1276
« Reply #10 on: September 16, 2005, 06:07:00 PM »
I'll have a look for you when the weather gets better and take a pic (I'm in Melbourne) could be awhile  ;) You will find that even the 235's are illegal on a 5.5" rim so why not put some 30x9.5's on as they are just a little bigger. I've had 33x9.5's on stock rims  ;D Is yours an auto or manual as the auto copes better with the bigger rubber due to the torque converter but tends to run away down steep descents a little more although driving through the brakes helps.
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #11 on: September 16, 2005, 06:09:10 PM »
One, I've heard that rotation the driveshaft can make a difference.  (Remove the bolts and rotate the drive shaft a 1/4 turn, then bolt back in and try)
If that don't work...
Get a angle gage, you should be able to find one at the local hardware.  Pull the drive shaft.  Now measure the the angle of the differential flange and the angle of the out put shaft.  They should be withing 6 degrees of eachother or they will cause a vibration.
Note:  There are those on the board that have gone way beond 6 degrees and claim not to have had a problem.  Myself I had a horible vibration on deceleration until I got the angles within 6 degrees and havent had a problem sence.
32 MTR's Warn 8000i
Offline pepperoni
  • 6
« Reply #12 on: September 16, 2005, 10:10:35 PM »
Thanks for all the info,
I played around with the angles again today and it seems a little better.  I actually started winding the rod end back in which has been opposite to what I thought I should be doing so maybe I haven't got my head around it yet.   If I get it right at this stage it will be all luck.
I've gotten some great info back about this and some sites to follow up.  I know the 6 degrees or less is supposed to be a simple thing to check out and I've already read sites simplifying it even more but I'm hoping I solve it before I start having to use a guage and pretend I know what I'm looking for in these angles.
CJ those 30 x 9.5's were they BF's or Coopers or what.  What brand do you reccomend.  I've been using those converters and the 235's are a tad under 29 inches.  Is that extra inch worth re-ordering for?
PEP
Offline suzukiboyoz
  • 194
« Reply #13 on: September 17, 2005, 06:09:42 AM »
I have 30" x 9.5 Wrangler MTRs great tyre heaps of grip.
You will pay about $200+ each for them.
Got a set of 15 x 7 CSA white steel rims for $200
Offline Gary_Hill
  • 288
« Reply #14 on: September 18, 2005, 12:51:32 AM »
Has anyone tried a cv drive shaft for eliminating angle vibrations. I had big driveline vibration on my 88 SPOA,  SR sam untill I went cv drive lines. Much smoother now.
