tranny swap questions?
  • 18 Replies
  • 4831 Views
Offline da_tub
  • 307
« on: September 19, 2005, 12:58:21 PM »
hey guys... was batting the thought around, about changing the five speed out and swaping it for an auto>>  i have a four door. and it's a 91... is the trans controlled by the computer.?  ithenk this would be so much nicer for wheelin, and because i'm lazy..lol( ;D) do you think i'm crazy or what also going to run 31's on it... just a thought whats yor input?
91 four door ,and some stuff
Offline Mythose
  • 361
Re: tranny swap questions?
« Reply #1 on: September 19, 2005, 01:06:32 PM »
well the tranny type is a matter of opinion,   to shift or not to shift,  I prefer the manual, and i do believe that the auto is controlled bythe Computer, however you could grab a computer and tranny out of a totaled 91 2DR or 4DR and you should be able to do a conversion with a little wire running.
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #2 on: September 19, 2005, 01:09:17 PM »
My 92 4 door had a 4 speed auto tranny with overdrive and it was computer controlled. I don't know what all you'd need to swap, but the 4 spped auto also has 5.12's in the diffs, the 3 speed autos usually run 4.62's and the manuals run 5.12's(again, usually)
Offline da_tub
  • 307
« Reply #3 on: September 19, 2005, 01:12:05 PM »
i have 5.34 gears i think ..can't remember.....
Offline Digger
  • 1991
« Reply #4 on: September 19, 2005, 01:22:50 PM »
You're right, 89-91 4 door manual transmission models did have 5.38's. I didn't know that and now have a better idea what to search for in the junkyard! LOL!(just searched on www.car-part.com )
If you could swap in the 3 speed auto from a 2 door that's used to 4.62's it would drive 31's really nicely with the 5.38's... ;) I think the 4 speed auto might be a more difficult swap than the 3 speed auto, it would need more wiring work. Plus gearing-wise it wouldn't gain you much...
« Last Edit: September 19, 2005, 01:26:34 PM by Digger »
Offline SnoFalls
  • 1358
« Reply #5 on: September 19, 2005, 01:43:15 PM »
<----- runs a '91 with a 3spd auto and 31's (and did the swap of 4.62's to 5.12's)
does great on the trails, and on the hwy tops around 65mph (climbing hills drops to around 50 mph). I think my engine is getting tired too so the hwy speeds are limited there I think.
5.38's would be just about perfect tho.
I like the slushbox (a bit of a pain in deep mud), but it can CRAWL :)
Offline da_tub
  • 307
« Reply #6 on: September 19, 2005, 11:52:42 PM »
thanks guys for the input. so you think the over drive would be to much work ,and boggy?  that's whats nitros is for..lol i think i'd go with the three speed though.. althoug the four would be nice for highway trips.... i'm i no hurry ..most of the time( ::))
Offline zaggy
  • 1134
« Reply #7 on: September 20, 2005, 06:58:47 AM »
Yo
     The three speed auto is not computer controlled and you could do the swap fairly easily.
But your gas mileage is going to go in the toilet as you lose the overdrive. 2dr or 4dr 8valve
trans will work fine. If I remember right you'll need
- Flexplate
- Trans and tcase with torque converter
- Front and rear driveshafts
- Kick down cable
- all the shifter stuff
The rest should be ok if memory serves.
It's still a big job though.
ZAg
Offline biker
  • 730
  • It's a sickness I tell ya
« Reply #8 on: September 20, 2005, 07:21:08 AM »
I just did this swap on my 91 2 door. The 3 spd auto is identical in length to the 5 spd std so no need to replace driveshafts. There is no wiring needed unless you want the nuetral safety switch working, all I did was hook up the vacuum line and a tranny cooler and drive. I run at 3800rpm at 100kph(60mph) with 5.12's and 33's
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline da_tub
  • 307
« Reply #9 on: September 20, 2005, 12:19:54 PM »
perfect.. thats just what a anted to hear!! sounds pretty straight forward... and i'm all about no mess no fuss..lol
Offline da_tub
  • 307
« Reply #10 on: September 20, 2005, 12:22:06 PM »
the trannys are all the same in length right? pretty surethey are...
Offline Digger
  • 1991
« Reply #11 on: September 20, 2005, 08:33:12 PM »
I just did this swap on my 91 2 door. The 3 spd auto is identical in length to the 5 spd std so no need to replace driveshafts...
Offline BV1
  • 58
  • X-90 fan :)
« Reply #12 on: September 20, 2005, 08:53:47 PM »
No you need new driveshafts.
Check my thread I just finished the OTHER direction swap.
http://www.zukiworld.com/forum/index.php?topic=8630.0
I have EVERYTHING you need for an AUTO swap. PM me if your serious.
-Steve
Offline biker
  • 730
« Reply #13 on: September 20, 2005, 09:59:00 PM »
Which version of the auto did you swap out as maybe the newer ones are different but if you are swapping with a 3 spd auto they are the same. I even swapped t-cases between the two and reused my old driveshafts with no problems
99 Vitara 2wd
10 Gr Vitara
Offline chet
  • 556
  • Zuki time!
« Reply #14 on: September 20, 2005, 10:02:05 PM »
the 4 spd auto (with the OD) are longer.
