gears, i think its a differnt Q
  • 10 Replies
  • 2930 Views
Offline 92Sidekick4x4
  • 1456
« on: March 23, 2005, 12:54:15 PM »
Hey everyone i think this is a differnt gearign question soo...
my problem is towing my quad, my kick absoulty sucks at towing it if i were to put lower gears in it would it tow better?? what gears would be good
i have a 5 speed if that make sa difference
  • 1456
Re: gears, i think its a differnt Q
« Reply #1 on: March 23, 2005, 05:09:35 PM »
anyone?
mudfkr
« Reply #2 on: March 23, 2005, 07:05:23 PM »
If you put  diff gears in it (5.83s) it would lower your high range (14%) and give it a bit more peep for towing.
Lower gearing ='s more grunt  ;D
How ever you can expect to use more gas as well  :'(
Offline 1bigtracker
  • 3409
« Reply #3 on: March 23, 2005, 10:02:00 PM »
what tire size are you running?
stu
Offline chet
  • 556
  • Zuki time!
« Reply #4 on: March 24, 2005, 02:18:57 AM »
gearing and more power! cam, header, air filter will all help as well.
  • 1456
« Reply #5 on: March 24, 2005, 03:24:09 AM »
i am running 30" tires, so 5.83's? eh what do they cost what else would change if i put these in?
  • 1456
« Reply #6 on: March 24, 2005, 04:13:48 AM »
also would i notice more fo a difference towin?
« Reply #7 on: March 24, 2005, 04:18:13 AM »
5:83s would be great for towing but are pretty expensive. A cheaper option might be to pick up a set of stock wheels and 195 tyres, I think you would easily notice the difference. The lower height would also give you a bit more stability.
  • 1456
« Reply #8 on: March 24, 2005, 05:24:56 AM »
hhmmmm but then it would look gay  ;) ;D, if i did the tires that is, what does a set of 5:83's cost?
Offline Cwkick
  • 888
« Reply #9 on: March 24, 2005, 05:35:20 AM »
http://www.puresuzuki.com/Ring%20&%20Pinion.htm
Then you have to have them installed.
Cwkick
Offline 1bigtracker
  • 3409
« Reply #10 on: March 24, 2005, 07:01:26 AM »
600 bucks puls shiping and another cupple hundred to set them up.  really the easyer and way cheaper way would be to put some small tires on it for towing.
also would 5.83's be too low for running on the high way with only 30's???
stu
  ÂÂÂÂÂÂÂ
