Track/Kick tranny interchange
  • 1630 Views
Offline IKUZUS
  • 21
  • You're right, I don't understand!
« on: March 23, 2005, 11:35:59 AM »
Will a tranny from a '95 1.6 8v Tracker/Kick (2 door, 2wd) fit a '92 1.6 16v 4 door 4wd?? I'm sure there will be something to change to make the tcase bolt up. Any help will be appreciated. Almost forgot.........both are 5 speeds.
« Last Edit: March 23, 2005, 11:39:42 AM by ikuzus »
You're right.........I don't understand.
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: Track/Kick tranny interchange
« Reply #1 on: March 24, 2005, 12:20:57 AM »
The 4wd Track/Kick tranny uses a married transfer case design, meaning it actually become part of the tranny and finishes the rear of the case. I'm not sure, but the 2wd tranny probably doesn't have any way to accept the Track/Kick transfer case without some fabrication. You could always use the 2wd tranny and get a transfer case from a sammy, they are separate or "divorced" in design and can be used behind just about any 2wd tranny... You might need new custom length driveshafts for that idea.
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
« Reply #2 on: March 24, 2005, 03:32:51 AM »
And with this set up your gear ratio will change very much, It'll be about 40% lower  :o
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
