QUICK TROUBLE SHOOT PLEASE 1.6 MOTOR
  • 2598 Views
« on: September 22, 2005, 10:18:43 AM »
My friend is working on a 92 Tracker and cant get it to run. He is getting fire and fuel to the motor but no injector pulse. Any ideas of what could be wrong?
Thanks Zig
Offline zaggy
  • 1134
Re: QUICK TROUBLE SHOOT PLEASE 1.6 MOTOR
« Reply #1 on: September 22, 2005, 10:33:02 AM »
I hate to say this but I think it's probly one of 2 places
- Poor connection or somehting hooked up wrong
- ECU
Typically no injector pulse from my experience is ECU
Best guess...
Zag
« Reply #2 on: September 22, 2005, 10:43:29 AM »
Cooll thatnks Zag, that was Mikes conclusion too. I will let Jimmy know.
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #3 on: September 22, 2005, 12:02:52 PM »
Zig, also when the key is in the on pos there should be 12V on one side ov the inj. conn. If there isn't you have a powefeed prob. and check the feed ckt.
     Kevin
Offline bandit86
  • 1641
  • elv8rguy
« Reply #4 on: September 22, 2005, 02:23:19 PM »
Thanks Zig
you cant have one without the other.
Offline locjaw
  • 2045
  • 22
« Reply #5 on: September 22, 2005, 05:32:51 PM »
had the same prob a couple of months ago on my nissan truck, took my mechanic 2 weeks to trouble shoot it cause everytime he would put the scanner on it it would fire up again(really messed with him)ended up being a corroded plug at the batt terminal that was the main power for the computer. had fuel press at the rail, had spark, would run when i would dump fuel into the air body.
look at those plugs, might be the problem
jason
Offline BV1
  • 58
  • X-90 fan :)
« Reply #6 on: September 22, 2005, 09:22:08 PM »
I had the same problem with my X when I did the swap,
I was getting fuel, fire, ignition, compression, detonation but no combustion?.....
Wait, that was a bad dream... nvm
-Steve
