Will this be ok?
  • 16 Replies
  • 4462 Views
Offline phewes
  • 9
    • phewes.snowpants.org
Will this be ok?
« on: September 25, 2005, 01:14:13 PM »
Hey guys!
I've done some more research and now I understand more about tires and rims size for trucks and jeeps.
I wanna know if they won't rub at stock height?
15x7  American Racing BAJA (polished)
With
30 / 9.50 / R15
http://cgi.ebay.com/ebaymotors/30-9-50-15-BF-Goodrich-All-Terrrain-KO-Tire_W0QQcmdZViewItemQQcategoryZ66473QQitemZ8002649641QQrdZ1#ebayphotohosting
Im picking it up this week! I can't wait! ;D
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
Re: Will this be ok?
« Reply #1 on: September 25, 2005, 02:17:35 PM »
235/75-15's rub on some TracKicks so I would say 30's are gonna rub somewhere without mods.
« Reply #2 on: September 25, 2005, 02:26:00 PM »
What backspacing are the wheels? The backspacing has as much effect on clearance as the diameter. The further out the wheels stick the greater the arc they travel.  15x7 is a good size for a 9.5 tyre. I am running 15x7s with 9.5 tyres (albeit 33"), I run 95mm backspacing, that seems to give the maximum clearance all round and brings the edge of the tread right out to the edge of the arch which means its just legal for road use over here.
« Last Edit: September 25, 2005, 02:29:49 PM by Rhinoman »
Offline phewes
  • 9
« Reply #3 on: September 25, 2005, 03:19:52 PM »
As for backspacing size.... its 6mm offset  and  3 3/4 inches.
Offline 92Sidekick4x4
  • 1456
« Reply #4 on: September 25, 2005, 05:19:04 PM »
I ran 30x9.5" tires on my truck a while ago, and the only place they rubbed was at full cock on the frame, no big problem, my cousin now has tyhose tires on her stock kick and it doesnt rub either.
Offline phewes
  • 9
« Reply #5 on: September 25, 2005, 08:25:14 PM »
Thats good to hear man!
I wanna to get an idea of height of the ride with those wheels on? By any chance you have any pics of hers?
That would help a lot!
Thanks!
Offline xoffroad
  • 153
    • PaWheelers
« Reply #6 on: September 26, 2005, 01:23:34 PM »
Nope, won't work. Only because of the Star Trek emblem on the front. You'll need to remove that. Warp speed will no longer be attainable in a trackick with 30's.
mudfkr
« Reply #7 on: September 26, 2005, 02:11:27 PM »
Interesting guard flares are they a stock sunrunner item or aftermarket ?
Those wheels will transform the look big time  ;D
Offline phewes
  • 9
« Reply #8 on: September 26, 2005, 03:03:47 PM »
Star Trek? LOL ;D
I know its the very first thing Im gonna remove!  Im gonna have the graphics removed as well...  gonna fix up some surface rust and bubbles at same time.
Yea those r stock fender flares!  ;D  its going to be a nice touch with some nice rims and tires! I love them! ;)
  • 6598
  • 68
« Reply #9 on: September 26, 2005, 03:33:36 PM »
Ok! I was thinking the same thing. Is that the actual Pontiac Sunrunner emblem or has someone put a Star Trek emblem on the car?
Offline TN_Tracker
  • 1113
« Reply #10 on: September 26, 2005, 03:38:44 PM »
My brother has 235/75 mud tires/aftermarket wheels on his Kick and they rub at full compression on the rear even with coil spacers. If phewes is going to stay on the street he should be OK but if he uses the Zuk off-road they will probably hit, I've seen it myself while wheelin' with me Bro. If your gonna spend money on bling tires and wheels why not get the lift and do it right? ;)
Offline explosivo
  • 3157
« Reply #11 on: September 26, 2005, 03:49:37 PM »
What backspacing are your brother's wheels, TN_Tracker? With 3-3/4" BS there might not be a problem as stock is 4-1/4", correct?
omghi2.us[/url]
Offline TN_Tracker
  • 1113
« Reply #12 on: September 26, 2005, 03:56:31 PM »
15x7 white spokes with 3 3/4" BS. Maybe my Bro's Kick is an oddity or Cooper makes some mighty wide 235's, I dunno.
Offline explosivo
  • 3157
« Reply #13 on: September 26, 2005, 04:04:23 PM »
Out of curiosity, where are they rubbing at? On the body? The frame?
omghi2.us[/url]
Offline TN_Tracker
  • 1113
« Reply #14 on: September 26, 2005, 04:10:33 PM »
Top of the rear wheel arch on both sides. Last run he bent the lip and cut the tires on both sides. ;D
