Tracker gears in a on a sammy carrier problem
  • 1994 Views
Offline brlj
  • 512
    • Bills 93 Tracker
« on: October 02, 2005, 07:08:02 AM »
Im putting Trackick 5.12's on a sammy carrier. I assembled the carrier with the aluminum diff can that holds the spider gear pins in. When I put the carrier into the 3rd member I got the backlash to about .010 . When I spin the assembly the aluminum diffcan hits the outer edge of the pinion gear. Has anyone had problems with the diffcan hitting the pinion gear like that?
Bill
Re: Tracker gears in a on a sammy carrier problem
« Reply #1 on: October 02, 2005, 11:56:49 AM »
You could be missing a trick gear shim that moves the ring gear over would be my guess.
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #2 on: October 03, 2005, 12:10:33 PM »
i have just done my vit into sammy 3rd
i took the carrier out of the kick one. the pinion out of the kick one put the pinion in the sammy 3rd and the kick carrier in the sammy 3rd , all fine? out using it yesterday
did you leave the sammy pinion in or the crown wheel,  ? sammy pinion is a big mother?
Markyb (UK)
UK Vitara JLX SE
Offline brlj
  • 512
    • Bills 93 Tracker
« Reply #3 on: October 05, 2005, 05:32:03 AM »
I didnt leave the sammy pinion in but what is the crown wheel? Also I didnt know I needed a gear shim where do you get one?
Thanks
