1993 sidekick jlx 4dr 4wd-TIRED 4cyl with 188,0000
  • 24 Replies
  • 6342 Views
0 Members and 12 Guests are viewing this topic.
Offline kirk70
  • 47
« on: October 03, 2005, 09:07:34 AM »
my 93 has a 3" calmini body lift with 33" mickey t's and complete camo-clad.   i use it as my hunting rig, but actually drive it more than my truck.  the moto has 188,000  miles and is tired.  that coupled with the big tires makes it moan and groan. sooooooo, what are my options?  could i put a newer bigger motor in?  would a calmini motor re-build kit do it?
Re: 1993 sidekick jlx 4dr 4wd-TIRED 4cyl with 188,0000
« Reply #1 on: October 03, 2005, 11:24:09 AM »
When my motor let loose at 280K after years of pulling 33's around. It made a HUGE difference just puting a rebuilt motor in it. You would be amazed at how much power is lost after lots of use.
Offline kirk70
  • 47
« Reply #2 on: October 03, 2005, 12:48:33 PM »
sorry for the ignorance, but you reuilt the original motor, or put in a completely different RE_BUILT engine.  someone had mentioned putting a newer 6 cyl in.  is that possible?
Offline SnoFalls
  • 1358
« Reply #3 on: October 03, 2005, 01:06:51 PM »
is that possible?
Everything is possible ...
A stock engine rebuilt, should do ok with 33's ... it's never going to win drag races, but if ya want that, get another car.
Offline kirk70
  • 47
« Reply #4 on: October 03, 2005, 01:27:09 PM »
what's the best and most affordable re-build kit?
Offline SnoFalls
  • 1358
« Reply #5 on: October 03, 2005, 01:42:27 PM »
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #6 on: October 03, 2005, 02:05:04 PM »
Did you ever regear to turn the 33's?
Offline kirk70
  • 47
« Reply #7 on: October 03, 2005, 02:14:16 PM »
no.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #8 on: October 03, 2005, 02:54:55 PM »
Is yours auto or manual?
The fact that you're turning 33" tires with gears originally ment for a set of 26-27" tires is probably part of the problem.
Offline zaggy
  • 1134
« Reply #9 on: October 03, 2005, 08:59:11 PM »
You could check out "do it yerself engine" thread
It's for an 1.6/8valve, but most it applies to the 16 valve (except obviously the head work).
Built similary you will get a power boost while you are at it.
Zag
« Reply #10 on: October 04, 2005, 04:29:15 AM »
I purchased an engine that had already been rebuilt.
Definately look into the re-gearing of the axles. It will help out allot.
Offline kirk70
  • 47
« Reply #11 on: October 04, 2005, 05:53:59 AM »
it is a manual transmission.  what gear ratio do i need to look at?  do i need to do the gears before or after the engine rebuild, or does it matter?
Offline kirk70
  • 47
« Reply #12 on: October 04, 2005, 08:17:04 AM »
i won't be doing in rock crawling.  just mud and mostly normal driving
« Reply #13 on: October 04, 2005, 08:27:46 AM »
Power is not a substitute for gears.
You are working that engine hard
on 33s with stock gearing, problem
is the 5.83 have been hard to get
from being out of stock, anyone hear
if they are shipping yet ???
The gears will cost about $600 and
another $100-200 to have setup, you
could look into a diesel swap for power,
and I think it will help with the gear ratio
too, any thoughts on that guys ???
« Reply #14 on: October 04, 2005, 08:36:29 AM »
PM GRVIT and see if the European Distributor still has any of the 5.83's. If not the 5.12 manual gears will help out allot and cost much less. I dont know any thing about a motor swap besides the fact I like things simple and a diesel swap sounds like a long drawn out process just to have a bit more power and allot louder motor to go hunting with  :-\  We do not allow any one to even drive up the field entrance in a diesel during hunting season because of all the extra noise.
Plus a Manual tranny diff swap will be lots cheaper and can be done in an afternoon.
my 2 cents,
