head gasket and intake gasket question....!!!
Dr_xXx
28
Yes Baby !!!!
October 03, 2005, 07:38:25 PM »
hi...my radiator is empty by the exhaust its probably head gasket or intake gasket.....
how to check witch one its broke ? i i dont have to change both im happy !!!
sorry for my english !!! thanks !!!
Sidekick 90 2 Door
3" Body Lift
2" Suspention Calmini
31 Mud BFG !!!
wildgoody
8134
67
Turbocharged 150HP 1.6L 8V 93MPH 1/4 mile
Re: head gasket and intake gasket question....!!!
October 03, 2005, 07:45:26 PM »
I think you are going to have to remove the
intake to get the head off, you might as well
change them both, but it probably is the head
gasket
Dr_xXx
28
Yes Baby !!!!
October 03, 2005, 09:34:00 PM »
i have to check my head whit profesional or whit my eyes its ok ?
Sidekick 90 2 Door
3" Body Lift
31 Mud BFG !!!
wildgoody
8134
67
Reply #3 on:
October 04, 2005, 08:49:55 AM »
If you know how to check the head for
warpage (not 100% flat) then you can
check it, but if not, go to an auto machine
shop and have it checked
Dr_xXx
28
Yes Baby !!!!
Reply #4 on:
October 04, 2005, 07:00:35 PM »
i change the motor...!!
thanks you !!!
Sidekick 90 2 Door
3" Body Lift
31 Mud BFG !!!
Suzuki1.8
283
Tires so low looks like i'm riding on blades
Reply #5 on:
October 04, 2005, 07:47:20 PM »
Acutally suzuki suggest if at all possible when changing a head gasket to keep the intake in place on the head. THe head will come off with intake intake. I just did my friends 1.8 which is alot complicated with the chain drive timing. I removed the head with intake on.
Suzuki1.8
283
Reply #6 on:
October 04, 2005, 07:49:33 PM »
Or by the way a good way to check for a bad head gasket. First check the oil. IS it milky? Second check the exhaust with a paper test that always a good sign to see if a head gasket is gone. and last but not least you can do a compression check to see if you got leakage in compression.
