Factory Alarm Gone Haywire
  • 3139 Views
Offline kemp
« on: March 21, 2005, 12:16:13 PM »
My 1997 SideKick Sport has a factory installed alarm system. For the past month or so it intermittantly will leave the tail lights and front blinker lights on..... repeated arming and disarming fixes it. Is this a short? Any help will be greatly appreciated    ???
Offline Suzuki1.8
  • 283
  • Tires so low looks like i'm riding on blades
Re: Factory Alarm Gone Haywire
« Reply #1 on: March 21, 2005, 01:31:47 PM »
I don't know i think the factory alarm is the cheapest thing ever built. Mine will sometimes only unlock the door and not lock it. Does your alarm make sound? mine just flashes lights.
Offline kemp
« Reply #2 on: March 21, 2005, 02:40:04 PM »
yeap it will sound a chirp while arming/disarming. There is even a alarm system manual that came with the car, but no in depth troubleshooting tips.
Still hoping its a simple fix.....
« Last Edit: March 21, 2005, 02:40:24 PM by kemp »
Offline Suzuki1.8
  • 283
« Reply #3 on: March 22, 2005, 12:34:19 AM »
did you check the fuses going to it? there are two fuses running the the controller box. you should check all the connections at the box to make sure its tight. the box is located behind the radio
Offline INGERSOL
  • 158
  • BIG, LONG, AND BLACK
    • INGERSOL.COM
« Reply #4 on: March 22, 2005, 03:49:08 AM »
Careful....I cut the wire from the alarm brain to the speaker, and one time the alarm went off (without me hearing it) so when I tried to start it, the engine kill switched prevented me from stealing my own car!  I tried disconnecting the battery for 10 minutes or so to reset it.....ended up towing the fucking thing back to the dealership, and had them cut every wire going in and out of that dasterdly device!
2003 Chevy Tracker
2.0 L Four Cylinder / 5-speed
Suzisport Headers
K&N Air Filter
Calmini Grill Guard / Tube Bumpers UK Factory Sunvisor RRO Coil Spacers Bridgestone Dueler Revo 235/75-15's
