Sami and Sidekick Interchangability
  • 2366 Views
Offline tsanchez
  • 26
« on: October 05, 2005, 07:22:27 AM »
Interchangability...is that a word??
Anyway - I own an 88 Sami and have an opportunity to get a 93 Sidekick for next to nothing.  It has some "motor issues" that the current owner is unsure of.
What parts are useful for both?  If the engine problems are minor, the engine in the kick would be an upgrade, right?  Anything else...tranny, rear end...??
« Last Edit: October 05, 2005, 07:39:35 AM by tsanchez »
Re: Sami and Sidekick Interchangability
« Reply #1 on: October 05, 2005, 04:40:26 PM »
Anything is posable, the engines do not
bolt up interchange, there are adaprers for
1.6L to the Sammy Trans, axles are different
but again can be modified to fit
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #2 on: October 05, 2005, 05:17:26 PM »
The engine upgrade would require a simple-to-install transmisssion and engine mount adapter kit.  A 1.6 engine would also give you the benefits of fuel injection -- helpful for preventing fuel starvation carbureted engines are prone to when operated at extreme angle as found when offroading.  Grafting the Sidekick harness is a bit difficult but not impossible.  You can even purchase a modified harness.  fuel injection also gets you better mileage.
Locking hubs are interchangeable.
Rear dif is only interchangable by grafting the complete pumpkin onto a Samurai  rear axle.
Front dif can be installed with the aluminum third member housing but is stronger when installed in a steel third member with an adapter kit.
Transmission and t-case are not an easy interchange as the t-case bolts directly to the transmission.  The Samurai has a divorced t-case.
Not much else is easily swappable.
for general FAQ information, try http://ackerdackerly.com/faqphpBB/index.php.
Ack
Offline tsanchez
  • 26
« Reply #3 on: October 05, 2005, 06:15:26 PM »
Sweet - Thanks for the answer, and the link
Overall, I'd have to say it would be worth it to have the 'kick just to tear off what I wanted and re-sell the rest.
Thanks
