Missing vacuum line on canister on right side of motor, wheres it go?
  • 1931 Views
Offline Festiva
  • 92
Hi guys, my 94 tracker has the canister on the left side of the motor, it has just a single nipple on the top of it (unlike some that have 2 nipples.) but no vaccum line hooked up, where does this go?
          Thanks!
                 Jason
Re: Missing vacuum line on canister on right side of motor, wheres it go?
« Reply #1 on: October 05, 2005, 04:42:18 PM »
Strange, should have 2, if you are sure
there is no purge nipple, the one should
go to the Gas Tank
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #2 on: October 05, 2005, 05:03:41 PM »
          Thanks!
                 Jason
Yep, there  should be two.  One has a hose that goes back to the gas tank, the other goes to a vacuum valve mounted on a bracket above and inboard of the thermostat housing on the front of the intake manifold (or thereabouts).  At least that is the case on my 93 and 96 16-valves.
Ack
