sidetrack conversion
  • 9 Replies
  • 2480 Views
Offline zuki4fun
  • 91
  • luv machine
« on: October 06, 2005, 05:38:35 PM »
well since i have two 4.3 v6s laying around and a blown engine in the sidetrack has any body got any info o n making one of these v6s go in the zuk? or is it realy out of the question
Offline 1bigtracker
  • 3409
Re: sidetrack conversion
« Reply #1 on: October 06, 2005, 06:25:07 PM »
pretty sure all Chevy drivetrain has to go with it if thats what your asking.
here is a little somthing
http://www.zukiworld.com/forum/index.php?topic=8535.0
Stu
Offline zuki4fun
  • 91
  • luv machine
« Reply #2 on: October 06, 2005, 06:40:37 PM »
no known adapters for the motor to zuk tranny?
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #3 on: October 06, 2005, 07:20:06 PM »
I have seen it done on a Samurai, (RangerRick) but I think the transplant included the transmission with it.
Ack
Offline toolman21
  • 229
« Reply #4 on: October 06, 2005, 07:26:18 PM »
Here is a place that will do it for you, never seen thier work, in fact I think I have heard negative things about it.  But it does prove it can be done.
http://www.suzukiconversion.com/
Toolman
Offline zaggy
  • 1134
« Reply #5 on: October 07, 2005, 07:18:03 AM »
If you find a way to bolt a 4.3 to a Kick trans......
You better stock stock piling trannies....they will blow!
Zag
Offline Festiva
  • 92
« Reply #6 on: October 07, 2005, 07:38:57 AM »
4.3 will fit BEAUTIFULLY!, ever see a tracker with the engine pulled? theres a ton of room.
350 v8 would be nice but pretty short front to back, so i could see where the 4.3 works out better. stock tranny might work, if you had an adapter, but for how long? you can probably use s10 5speed and transfer case or a 700r4 trans.. and those 4.3's can really fly!,
Easiest bet would be to order up a edlebrock carb and 4.3 intake, headers and a nice lopey cam...
Stupidest move i ever made was NOT buying a 350v8 powered samurai a few years back.. that thing would like the front wheels off the ground a foot when it got 2nd gear!, but it was a little tooo insane i think, and you had to be a gymnast to climb into the drivers seat with all the roll bars.. who really wants to doo all that when your tired int he morning stopping at starbucks for a coffee on the way to work? heh..
Offline Mythose
  • 361
« Reply #7 on: October 07, 2005, 07:57:26 AM »
well if your going to bolt the 4.3 to the zuk tranny zaggy is right, they will not last with that much power bieng dropped into them,  I would go with say a 4.3, a th350 and get you a good transfer case like the 205. "th350 ande 205 are a married unit" and the th350 is shorter then the 700r4 and a better tranny all around. but i am a manual gear box guy, go get a 4x4 s10 or blazer with a blown motor or that is totaled for 2 - 500 $ and swap it all into the kiktrak  have SAS and LOTS o power.
my .2
Offline toolman21
  • 229
« Reply #8 on: October 07, 2005, 08:57:49 AM »
If I am remembering correctly (which is debateable) the TH350 is a 3-speed unit, and the 700R4 is an overdrive unit which would be nice.  I think there is a 200R4 or something that is smaller and has overdrive....or something like that.
Either way just find a tranny/transfer case from an S-10 to use, the output comes out on the correct side, and you wont' need any expensive adapters to use a Toyota.
Toolman
Offline Mythose
  • 361
« Reply #9 on: October 07, 2005, 09:59:26 AM »
I duno really my sub has a turbo 350 with a B&M shift kit, never feal it shift  LOL i think thats why i actually like it i hate the typical autos that have a shift lag.
